Active Member
Finding brake parts...
My mechanic is telling be that I need new/ replacement drum brake backing plates, trouble is we can't seem to locate them anywhere. I have tried the usual suspects CPP and LMC, Summit and Jegs with no luck. Any suggestions? This is for a '72 C10.
Thank you, Fred |
Re: Finding brake parts...
i work at autozone and can check if we carry them for your tomorrow. if not, junkyard's gonna be your best bet. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
71 rustless in texas
According to AutoZones web site there arn't any available for a 72 C-10.
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" ![]() 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE |
Location: vacaville ca, because it as far from indy as i can be
why would you need new backing plates??? its a no wear item.
Active Member
Thanks guys,
I appreciate the input. As I understand it backing plates are a no wear item, but 35 years of service tells me differently, donno why it's just one of those things... -Fred |
Your location in your Avatar would help.
Give me a day or two ... I may have some. You can have them for the cost of shipping IF I can find them.
ok so why are wanting new ones?
do you just want new look or is there actually something wrong with them? |
Active Member
Thank you Shane,
To answer T77's question. Here is the picture of the part that I need. I can not vouch for the history of my trucks braking system for the past 35 years, it would ssem to me that at some point the drums were serviced and the backingplates were not correctly reinstalled. They are worn, pitted and have lost physical material. I understand that backing plates are a non perishable part, I'm just looking for 2 new ones or 2 that are in good conition. -Fred Last edited by KFreddy; 02-03-2007 at 10:58 AM. |
its all about the +6 inches
When people don't put grease on the rub spots, the shoe can rub right through. I'm willing to bet, most of us actually have the wear marks on there... it tells you where to put the grease.
![]() If you can't locate any good ones, then see if your mechanic... or another one... can weld the hole shut. Shouldn't take more than a nr... maybe 1 1/2 hr labor to build it up and grind it smooth |
Active Member
![]() Join Date: Jun 2002
You can also use backing plates from a newer truck. I used backing plates and new internals for an 81 GMC. Bought 4x4 drums from same year to keep 6 lug on my 69. They are bigger/better and now cheaper to do brake jobs.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
![]() Join Date: Mar 2003
I weld up the rub spots ALL THE TIME. Hit 'em with the wire feed and then my air sander--takes maybe 15 minutes per backing plate
#13 |
Active Member
Thank you all for the suggestions,
I think that the weld and grind technique is the answer. Thanks again, Fred |
