![]() Join Date: Nov 2006
Worlds Best And Cheapest Engine-chassis Degreaser
OVEN CLEANER !!!!!!! works perfect and its a buck a can .the no name stuff works just as good as the hi-dolla brand too......
bob |
Alright Alright Alright
Re: Worlds Best And Cheapest Engine-chassis Degreaser
i use aircraft paint remover on everything. it eats though grease, oil, and carbon like nothing. i can put a layer on an old piston and it will look brand new when i clean it off.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
#3 | |
![]() Join Date: Mar 2006
Oven cleaner is great but make sure you use it in a well ventilated area or you will be coughing like the first time you took a hit of...well, you will cough a lot! Be safe!
1986 C10 - LWB, 305/700r4, posi, vortec heads |
I used to only see this stuff at auto parts stores. But the last time I was at Wal-Mart it was in the automotive department by the paint. It's kind os a white and blue can.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
oh, thats just what its called on the can. you can get it at any auto parts store or walmart. it is in gel form and i usually apply it with a small paint bursh. it is the best thing i have ever used. i hear that oven cleaner can stain aluminum parts.
Chevy truck addict
yea tha aircraft stuff is good. just make sure you wear gloves it burns if you get it on your skin
67 c10 250 I6 3 on the tree no options air ride, paint and big block coming within the next 23 years 2001 mustang gt for going fast |
[QUOTE=crm318;2014435]oh, thats just what its called on the can. you can get it at any auto parts store or walmart. it is in gel form and i usually apply it with a small paint bursh. it is the best thing i have ever used.
comes in a spray can also
69 chevy swb 2.5 in droped spindle with 1 coil cut--5 in dropped spring in rear 5 in dropped spring 307 repaced soon with 350 3sp on tree soon replaced with 350 tubo 06 monte carlo 94 chrysler town & country---198K 84 jag xj6 76 sportster---57 panhead |
i put that aircraft paint remover on my arm as a dare...wasnt as bad as they said it was so needless to say they were pissed when i was fine but it was fun when we got a couple other friends to do it but yea it works REALLY GOOD though and ill have to try the oven cleaner
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
River life......
Burns your eyes also, definitely wear goggles with this stuff. Oven cleaner works, but if your parts are warm it works better.
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Yea, they were good times!
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
Active Member
Today's aircraft paint stripper is not what it used to be. Not quite as strong. I still like it best for paint removal. It is a bit pricey so I use oven cleaner for degreasing. Dollar for dollar, I choose oven cleaner for cleaning dirty parts.
1969 C-10 short fleet 2wd. 400ci. w/350 Turbo. '68 front clip and factory wood bed floor. 3"/5" coil drop. 1971 K-10 short fleet 4wd. Partial project truck. 1972 K-10 long fleet 4wd. Complete project truck. |
#13 |
Diesel,kerosene,and gas all work great.If not,light a match.lol
#14 |
If you wear eye glasses DO NOT get any overspray from the oven cleaner on them.I was not thinking about it & just got a few speckels on my glasses & it ate right into the plastic lens.
#15 |
Keep in mind that oven cleaner will remove the paint right along w/the grease & soil. Simple Green works well for grease/oil clean-ups w/o damage to most paints.
#16 |
i worked at schiphol amsterdam airport on the big passengerplanes as a painter/sander and once got the thick black goo on me .
it got on my sleeve when i was working and as i wiped the sweat of my forhead and instandly knew i done something BAAAAAAD no water in about a mile around to flush the dahm stuff off and all the lowels allready had the goo on it . i had to walk around for a while with a big red chemical burn line across my forehead
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#17 |
I Did It At 28 Degrees Outside And That Oven Cleaner Did Perfect And Did Not Hurt The Engine Paint Or Aluminum......
#18 | |
I use it as part of my prep to strip engine blocks of grease & old paint. It will eat the paint off.... maybe not all paint/paints, but why roll the dice.
#19 |
wnc tvman
can you use oven cleaner to strip body paint?
Oz WNC 67 Short Fleet 350 4speed 70 Short Fleet 327 4speed |
#20 |
What will clean my oven?
#21 |
THAT'S FUNNY! |
