Old 02-02-2007, 11:50 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Need help to determine drop.
My truck came lowered & supposedly with dropped spindles & springs. But I have no idea how to tell what was really done. The springs look new (silver in color?) but not sure how to tell what spindles I have.
Can someone measure the fender lip to center of wheel so I can determine my drop?
It needs to be fender to wheel center as wheel/tire size wont effect this measurement.
I’m assuming a lowered truck will require a different shock than stock ride hight. Is this correct?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-03-2007, 12:18 AM   #2
jimmydean
jimmydean's Avatar
Re: Need help to determine drop.
I am running stock shocks in the front. The rear are 3" lower with shock relocators, but my truck is bagged.
Look at the back of the spindle. If the spindle is at teh bottom, it's stock, if the spindle is more toward the middle, it's dropped.
Drop on the left, stock on the right:
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-03-2007, 12:28 AM   #3
Sport/Truck
Sierra Grande Club
Thanks, I’ve only looked from the inside at the spindle & it don’t look like a lot of drop..
Old 02-03-2007, 12:19 PM   #4
Sport/Truck
Sierra Grande Club
Can anyone measure the stock height for me?
Old 02-03-2007, 10:48 PM   #5
Sport/Truck
Sierra Grande Club
ttt
Old 02-03-2007, 11:35 PM   #6
see ten
WTB this ad
see ten's Avatar
Well how about a measurement from a dropped truck? I'm looking about 14.5" give or take. My truck has a 2.5" drop spindle and a 1" drop coil. So I guess stock height would give you a measurement of 18" give or take a smidge.
see ten is offline   Reply With Quote
Old 02-03-2007, 11:46 PM   #7
70c/10barebone
Junior Member
70c/10barebone's Avatar
My stock height front is 20 3/4". Rear is 20" but I've got a few hundred lbs of tools and junk in the bed. Hope this helps. Craig
70 C/10 LWB 250
70c/10barebone is offline   Reply With Quote
Old 02-03-2007, 11:50 PM   #8
DangerBoy
According to the LMC catalog with stock tires and springs the top edge of the fender on a 2wd should be 36" from the ground. So 18" to the center of the wheel sounds about right.
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline   Reply With Quote
Old 02-04-2007, 08:43 AM   #9
Sport/Truck
Sierra Grande Club
cool, thanks.
