Old 02-02-2007, 11:57 PM   #1
gmoney
35in tires on 4inch lift
Whats up guys can anyone tell me if there is a clerance problem running 35 in tires on a 4 inch lift on a 72 K5.:
gmoney is offline   Reply With Quote
Old 02-03-2007, 12:01 AM   #2
1969k10stepside
Re: 35in tires on 4inch lift
They will work,if you are wheelin there will be rubbing.A driver with 35s and a 4" lift will have no problems
1969k10stepside is offline   Reply With Quote
Old 02-03-2007, 10:06 AM   #3
billyjo
Junior Member
billyjo's Avatar
I've got that combo, as stated they'll rub if you off road but I added the zero rate kit and moved my axle 1" back and I don't rub anymore.
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's.....
http://s72.photobucket.com/albums/i1...tos/?start=all
billyjo is offline   Reply With Quote
Old 02-03-2007, 10:58 AM   #4
8" rims instead of 10" helps,too.
Old 02-03-2007, 11:51 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
My 35's rub with a 6'' lift on 12'' wide wheels..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-03-2007, 12:43 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I have a staggered lift, 4" front and 6" rear, 8" rally's, no issues, but I don't wheel it
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-03-2007, 10:17 PM   #7
Mike C
Mike C's Avatar
I have 35" BFG MT's on 15x10 Centerlines with 3.5" BS. The passengers fender rubs in the front where it was smacked 20 years ago. I cut the front of the rears. A pie piece about 1" at the bottom tapering up 6" or so. Makes the fenderwell a much better shape IMO. But I can stuff the fronts into the back of the fender when going through ditches at any angle. But on the street, it's no problem at all. I'm getting ready to put 36 inchers on it with an 8 lug swap and we'll see what happens...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-03-2007, 10:59 PM   #8
pumpkin
pumpkin's Avatar
4" lift, 35 Mud TA's and no rubbing.
pumpkin is offline   Reply With Quote
Old 02-04-2007, 07:03 AM   #9
vtblazer
vtblazer's Avatar
pumpkin, come on your just playin' with us.
That last pic has the front tire SO into the fender.
vtblazer is offline   Reply With Quote
Old 02-04-2007, 08:55 AM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Old 02-04-2007, 12:19 PM   #11
pumpkin
pumpkin's Avatar
No ****,,,,, it does not rub, its realy close, but doesn't even polish the paint on the inner fender.It use to rub on the rear when I had lift blocks, but when I did the shackle reversal it looked after that.
Old 02-04-2007, 03:46 PM   #12
vtblazer
vtblazer's Avatar
Must be the pic then.
From the angle it looks like if you were to straighten your wheels it'd push the fender out, it must have better than half the tire hiding behind the wheel opening...oh wait, you gotta still be playin' with us on this one.
Photo angles can't distort thing's that much.
Old 02-04-2007, 04:26 PM   #13
1969k10stepside
To be fair,it looks as the fender cup was cut on the front.I personally dont see how that tire didnt cause body damage when it was turned on the rear of the front fender
Old 02-05-2007, 08:00 AM   #14
Pumpkin,there`s no way that tire in that position could be straightened out and not "rub" the fender.I can hear the p/s pump chirpin`now.You drove up that thing with the wheel cut hard in the position it`s in.Sorry,I know these things too well.
My truck with 6" lift,35" Xterrains,and 10" wheels gets some rubbing.I ran 7" lift,13x37" Swampers,and 8" wheels with no rubbing on a Blazer.
Old 02-05-2007, 11:46 AM   #15
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Plus his fenders looked trimmed. That's cheating!!!
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 02-05-2007, 04:18 PM   #16
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Old 02-06-2007, 04:14 AM   #17
bad_turbo
turbo enthusiast
bad_turbo's Avatar
yah, those fenders, front and rear, have been modified
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 02-06-2007, 06:30 AM   #18
Heck,I ran 14.50/37s with a 4" lift and 10" wheels.....and cut fenders
Old 02-07-2007, 05:11 PM   #19
pumpkin
pumpkin's Avatar
Yup you caught me, they are stretched a tad bit. I didn't turn them on the stump, but Ive been in wheeling spots that outa shape and the only rubbing is on the left rear front. It polishes the paint and sounds like a baseball card in the spokes of a bicycle.
Old 02-07-2007, 06:06 PM   #20
1969k10stepside
We knew it You cant fool us!
