Alright Alright Alright
white smoke on initial start up
i just started up a rebuilt 350 with vortec heads. as soon as i got it running, i reved it to 2000 reguardless of the timing. i tried to put it at the best timing to let it run. the exhaust was pumping out a slight white smoke that didnt smell like coolant and i didnt see any bubbles in radiator. the temp rose to about 195 and started to climb, which i assumed that the bad timing was the reason of the hot temp. the exhaust not sounded off to. tomorrow im going to start it back up, let it idle, and set the timing. what do yall think?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
Re: white smoke on initial start up
Normal. Run it awhile then see what it does.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
could be water left in the exhaust. play with the timing quickly and finish braking in the cam it should be alright.
NOT REALLY BANNED!
![]() Join Date: Jul 2004
Could've bent a valve from the wrong cam timing.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
what kind of rockers are on this engine? they should be self aligning rockers,
on vortec heads. just a FYI theres a few limits on cam lift and spring seat pressure with stock vortec heads without mods. the first two pictures show self aliging rockers the last one is a reg style rocker. hope you get it worked out.. your pal mark Last edited by rage'nrat638; 07-12-2007 at 06:58 AM. |
yea, im using the self aligned rockers. the cam is .440/.440 lift which is under the .450 limit
