Old 02-03-2007, 04:52 PM   #1
Cody chance
converting a 2X4 to 4X4
i have a 72 C20 with a 402BB. i want to know if i would be able to convert from 2 wheel to 4 wheel on this frame? what all would i need to switch to do so?
sorry im learning
Cody chance is offline   Reply With Quote
Old 02-03-2007, 05:09 PM   #2
watahyahknow
watahyahknow's Avatar
Re: converting a 2X4 to 4X4
the front of a 4x4 chassis is different it has leafsprings and other hangers for that .
the thing i would do is find a 4x4 chassis with the axles transfercase and possibly the gearbox/automatic still in and build you 4x2 sheetmetal electrics and motor ontoo that or trade the whole truck in for a 4 x 4 version and safe youreself a LOT of work
there are a couple of threads on the subject theres allso one on http://www.chuckschevytruckpages.com/2wdto4wd.html
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-03-2007, 06:15 PM   #3
1969k10stepside
You can but I say dont unless you can fabricate.This isnt a bolt in conversion.Your truck,a 3/4 ton already has leaf springs,correct?If they do thats going to make it a little easier.The frame on the backs are different with coil springs as to a leaf springed truck.The front....thats another story.New motor crossmember(about $50 used) and a transfer case crossmember($50-$100),leaf springs,shock mounts,the axle its self are needed...and everything else,which are not cheap BTW.IMO,your better off buying a 4x4 chassis and put your truck body on if your truck body is good,best option is to buy a 4x4.Also,you will need another transmission and transfer case.They run sorta high also.Plus,4x4s and big blocks dont go together without modifications....Dont even ask about using a newer 4x4 frame,thats as hard as converting this frame
1969k10stepside is offline   Reply With Quote
Old 02-04-2007, 01:19 PM   #4
Cody chance
so it can be done with it will cost me. well that fabrication is no problem i can do that.
so i would have to get a front axle and build the suspencion for the front end and put in a new transmission and a transfercase?
Old 02-04-2007, 01:38 PM   #5
1969k10stepside
Yep
Old 03-14-2007, 01:51 PM   #6
Cody chance
as far as having the big block would i have any problems with that?
Old 03-14-2007, 03:47 PM   #7
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
I asked the same question not long ago here's the thread with some useful info. My was on 1/2 ton though and there again not sure on the differences.
http://67-72chevytrucks.com/vboard/s...d.php?t=230856
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-14-2007, 04:51 PM   #8
vtblazer
vtblazer's Avatar
Here's a link to a frame sire, it may help answer a couple of your question's.
http://www.chuckschevytruckpages.com/framespecs.html
Make no mistake about it, your heading into a buttload of work.
Best of luck.
vtblazer is offline   Reply With Quote
Old 03-15-2007, 11:09 AM   #9
Cody chance
so according to the frame chart, the C20 front end should be the same as the K20? everything should mount up with some fabrication and welding...
Old 03-15-2007, 06:14 PM   #10
jacobs
jacobs's Avatar
Of course they aren't identical but close enough and with a little modification you can make it work.
I didn't move my 350 engine back like the factory did so clearance between the engine and the front differential is tight. With a big block, you might have to raise the front end.
jacobs is offline   Reply With Quote
Old 03-15-2007, 07:19 PM   #11
CrashEd
72 chevy
CrashEd's Avatar
I got a 2wd made into a 4x4 if you need pictures. I didn't do the change and theres a lot i would of done diffrent. Theres a lot i will change to on it.
Ed
CrashEd is offline   Reply With Quote
Old 03-15-2007, 07:26 PM   #12
Cody chance
Yah that would be great if you could post me some pics ED. about how long did it take you to do it?
Old 03-15-2007, 11:00 PM   #13
RACINJASON22
GEARHEAD
He didn't do it. So I think it will be hard for him to tell us how long it took. I'm interested in any pic's you might have also CrashEd RJ22
Old 03-16-2007, 12:09 AM   #14
CrashEd
72 chevy
CrashEd's Avatar
Ill get some pictures tomorow.
Old 03-16-2007, 12:19 AM   #15
GMCMAX
Active Member
GMCMAX's Avatar
I took two weeks off over Christmas/new years to do mine, had to follow up a weekend after that for loose ends. Bought everything from a blazer that was made into 2wd. Lucked out that the front axle had the same gear ratio as my rear.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 04-07-2007, 06:49 AM   #16
vjthibeault
NH
well I am in the process of doing the same to my 3/4 ton gmc.I have the frame done and the front installed but right now I am having some probs. with the tranny/transfer cross member. I also added in a 454 tbi out of an 88 and a 6" suspension lift so I am encountering issues all the way around but I just take my time and work through them The frame change wasnt all that bad I think it took me 2 days I will see if can get some pics today for you.
vjthibeault is offline   Reply With Quote
Old 04-07-2007, 03:37 PM   #17
Cody chance
That would be great. what tranny are you using? i have a turbo 400
Old 04-10-2007, 08:53 PM   #18
vjthibeault
NH
sorry I tried to load some pics but I have to resize them. If you want shoot me your email and I can email them to you. I am also using a t400.
Old 04-10-2007, 10:10 PM   #19
67chevytodd
Junior Member
I'm starting one of these also, but i have a 1974 4x4 donor that I plan to put my 72 cab on. The frame demensions are similar and the cab mount holes are the same the only thing I see that is different is the radiator support brackets. What is so bad about old cab to new frame swap?
Old Chevys never die they are just reborn!
67chevytodd is offline   Reply With Quote
Old 04-10-2007, 10:19 PM   #20
1969k10stepside
the frames are longer on the 73-87s by a few inches,from what I heard.The frame is made different making a body lift required when doing the swap.....just a few things
Old 04-14-2007, 09:45 PM   #21
Cody chance
my e-mail is codymi@hotmail.com
