02-03-2007, 07:37 PM | #1 |
Anybody put a Big block in 1971 Blazer?
I'm restoring my 1971 K/5 Blazer 4 x 4 with a 4 speed transmission and I want to put a big block in it. I'm wanting to know from somebody who has done this what all was involved in doing this. I would love to see some pics if possible.
Thanks, Gary |
02-03-2007, 11:30 PM | #2 |
I'm a poor spectator
Re: Anybody put a Big block in 1971 Blazer?
I put a 396 in mine but took it out after I realized I would have to either put on a body lift (at least 2 inches, maybe 3) or move the engine and transmission crossmembers forward. I didn't do any of those things simply because I wanted everything else to still be factory specs and moving everything around didn't afford me that.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
02-04-2007, 08:56 AM | #3 |
The LuvShack Garage
Nope, but From West TN
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-04-2007, 02:20 PM | #4 |
Im puttin a BB in my 2wd, engine is still on the stand and waiting patiently. It is not a problem slipping these in, they just take up a little more space. Only thing is to try to get it back to the firewall as close as possible to get a little of the extra weight on to the back wheels.
darren
67- 72 Parts collecter |
02-04-2007, 04:06 PM | #5 |
Purple People Eater
mine has a 396 in it (bought it like that 9 days ago). It has a 3inch body lift on it to make room. The rest of the driveline is pretty much stock except for a shift kit in the TH400 and 4.88s in the differentials.
1971 K5 Blazer 396ci/TH400/NP205/Dana 44/GM 12 Bolt/38" TSLs 2004 Chevy 1500 4X2 X-Cab 327ci |
02-04-2007, 05:13 PM | #6 |
I am thinking one of the smaller 502's would be just about right for my 70 2wd!
Kevin LFD Inc. |
02-04-2007, 07:20 PM | #7 |
just hope the transfercase is up to the task
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
02-04-2007, 07:50 PM | #8 |
One like this, someday!!!!!!!!!!!!!!!!! It would be nice to get it off the stand
02-04-2007, 08:55 PM | #9 |
I have a 454 with no body lift and the motor is as far back as it'll go. You just need to use a small capped distributor.
02-05-2007, 12:23 AM | #10 |
Put one in this Blazer of my son's (orangeuavol):
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
02-05-2007, 12:38 AM | #11 |
We installed it on the smallblock stands and mounts and had to cut holes in firewall for valve covers to clear. Just made small boxes and welded then inside cab to cover holes. Also used stock BB exhaust manifolds. Even used SB fan shourd by cutting a small amout off the side toward engine. (used 400T and NP205)
These pictures may help: http://pg.photos.yahoo.com/ph/jason_burkhart/my_photos
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer Last edited by jhow66; 02-05-2007 at 12:40 AM. |
02-05-2007, 11:42 AM | #12 |
Post Whore
I have a bbc in my 69 K20. You can see info on it in this link I'm going to make some changes at some point to get the body lift down to 2".
Burt4x4 put a bbc in his K5 a while back with minimal body mods.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
02-05-2007, 11:49 AM | #13 |
Yup I slaped in a 454 with SM465 trannyin my 72K5. Took a couple of months but works great. I can't get to my online pics right now as the site is down...
Go For It! Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
02-05-2007, 02:01 PM | #14 |
I put one in my '72 Jimmy, but to clear the distributor and not use a body lift, I had to move the engine and transmission/transfercase crossmembers forward 3/4". Also went to a four core radiator.
I think I'm safe in saying that if you use stock valve covers and small cap distributor you wouldn't have to modify anything except the radiator shroud.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
