Old 02-03-2007, 11:24 PM   #1
dave666693
dave666693's Avatar
Brake question
I did the rear brakes on my '68 C10 today and am wondering what the spring around the outside of the drum is for. I have never seen that before. Thanks
dave666693 is offline   Reply With Quote
Old 02-03-2007, 11:39 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: Brake question
From what I have heard it was a device to help cool the drum by helping air movement.. But I cannot confirm it.
Livrat is offline   Reply With Quote
Old 02-03-2007, 11:53 PM   #3
FarmTruk
In Memoriam...
FarmTruk's Avatar
Re: Brake question
I dunno either, but I thought it was to help control vibrations which would otherwise result in brake noise. To kinda dampen things a bit.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 02-04-2007, 12:03 AM   #4
rage'nrat638
rage'nrat638's Avatar
Re: Brake question
the spring is supposed to dampen shatter
it's the same thing when they trun a drum (resurface) it on a machine.
you will see them wrap a big rubber band (strap) around it.
how well it work's?
rage'nrat638 is offline   Reply With Quote
Old 02-04-2007, 12:35 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Brake question
when i still had the GMC, the drums had these things, when one flew off, that side rang when goin down the road.
Io was pretty p!ssed when i replaced 2 of them, and they had no provisions for the spring. But, luckily, the new ones didn't vibrate, but they did wear VERY poorly.
This was the same Q I had my first day i logged onto this site.
Old 02-04-2007, 12:20 PM   #6
dave666693
dave666693's Avatar
Re: Brake question
Thanks guys. I forgot to put one of them on before I put the wheel on so I think I will run without it for a while and see if I notice anything. I'm thinkin' I won't be able to tell the differance.
