Old 02-04-2007, 11:29 AM   #1
MyakkaJeff
Junior Member
Auto Tranny ID ?
Hey Guys, popping over from the 60-66 board, kinda quiet over there. I have a 400 pontiac motor with a auto tranny bolted to it. Previous owner tried to install it in my 66 truck. Who knows? Anyway, I've pulled it and may want to use the tranny on a sbc. How can I identify what this tranny is? TH350 or 400 or what? Thanks in advance, Jeff.
MyakkaJeff is offline   Reply With Quote
Old 02-04-2007, 11:31 AM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Auto Tranny ID ?
The pan on a 350 is almost square with one corner shaved off,the 400 is irregular shaped.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 02-04-2007, 11:59 AM   #3
MyakkaJeff
Junior Member
Thanks WorkinLonghorn, It's a 350 then. I guess it's a short tail shaft also (about 6" long). Are there date codes on the casing anywhere?
Old 02-04-2007, 12:34 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you'll need an adapter to bolt it to a chevy engine... not really worth the cost or effort.
The cheap adapter isn't worth the money. I think the trans-adapt is the one the caddy guys recomend.
Old 02-05-2007, 02:44 AM   #5
Americanrider
A bookmark you need to save, Link to Hurst Shifter website Tranny ID chart:
http://go.mrgasket.com/pdf/trans_id.pdf
Americanrider is offline   Reply With Quote
Old 02-05-2007, 10:00 AM   #6
cooters
turbo 350 and 400 trannys came in 3 belhousing styles, a chevy, a buick, olds and pontiac, and one that has all the holes for all of them.
cooters is offline   Reply With Quote
