02-04-2007, 03:44 PM | #1 |
stepside frame???
I was wondering if a short step frame and a short bed frame are the same? and if you could put a short bed on a step side? thanks
It's better to be dead and cool than alive and uncool |
02-04-2007, 04:15 PM | #2 |
Re: stepside frame???
SWB (short wheel base) frames are the same regardless of which bed they came with (fleet or step).
The differences would be found in 4wd vs 2wd, coil spring vs leaf spring, short wheelbase vs long wheelbase, etc.
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
02-04-2007, 05:03 PM | #3 |
its all about the +6 inches
yep. a short step will bolt right onto a frame that had a short fleet. Make sure you get the tail lamp harness for the correct bed.
