02-04-2007, 07:16 PM | #1 |
Gettin CONFUSED!
Ok today i went to pick a part and got this braket of a 69? I am wanting to put power disc brakes on my truck,69 1/2 ton 2wd.What do I need for this bracket to work?-Or will it? Thank you.
-Lance |
02-04-2007, 07:26 PM | #2 |
Re: Gettin CONFUSED!
that bracket is for a 3/4 ton booster...
the half ton booster bracket looks like this Last edited by rage'nrat638; 07-12-2007 at 06:58 AM. |
02-04-2007, 07:29 PM | #3 |
this is the 3/4 booster.. the 3/4 is better it's dual diaphragm
02-04-2007, 10:35 PM | #4 |
So it will work for 1/2t with disc brakes?(the 3/4 ton booster) what a bout a m/c?
02-05-2007, 09:42 PM | #5 |
ttt
02-06-2007, 02:21 AM | #6 |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-06-2007, 12:46 PM | #7 |
try this again. please HELP! Can I use a 1969 c20 booster and bracket with a 71-up 1/2t disc braks m/c and prop valve? Thanks
-Lance Last edited by manimal; 02-06-2007 at 12:49 PM. |
02-06-2007, 05:50 PM | #8 |
Firefighter
Still not clearing up the diff between the two brackets?? As with the booster they had the option of a Delco Moraine or a Bendix, the Delco being the single diaphram or the Bendix being a dual diaphram.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
02-06-2007, 05:59 PM | #9 |
Firefighter
manimal I don't see any reason why that wouldn't work just fine.
02-06-2007, 08:24 PM | #10 |
ok i am going out to the garage to shoot more pictures.. just for you guy's
02-06-2007, 08:38 PM | #11 |
ok lets see if i can splain
this picture is a 1/2 ton booster bracket Last edited by rage'nrat638; 07-12-2007 at 06:57 AM. |
02-06-2007, 08:40 PM | #12 |
this is a 3/4 ton booster bracket
02-06-2007, 08:49 PM | #13 |
tons of posts on this topic...search and ye shall find. From what I understand is a 1/2 ton MC goes with a 1.2 ton booster, and 3/4 ton MC goes with a 3/4 ton booster. Not sure on the brackets but those two are for sure. Now if I remember the two MC's are different front goes to back brakes and back to front on one and opposite on other. All this comes into play when you plumb it. I plan on researching it again prior to my install
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-06-2007, 08:51 PM | #14 |
here is the 1/2 ton booster..you can see the rear rod sticks out much longer than the 3/4 ton booster..
02-06-2007, 08:55 PM | #15 |
the 3/4 ton booster rod sticks out 3 1/4" long i don't have a picture with a tape measure beside it
02-06-2007, 09:09 PM | #16 |
if your going to disk brakes you will need the matching master cyl for the booster your using. designed for disc brakes and provalve.
if using a 3/4 ton booster on a 1/2 ton the lines need reversed. front to back...back to front after that your on your own..hope this helped your pal mark |
02-06-2007, 11:16 PM | #17 |
Thank You VERY MUCH!!
02-06-2007, 11:27 PM | #18 |
some 3/4tons and 1-tons ran the same booster as the 1/2tons.
02-07-2007, 05:19 PM | #19 |
Just got off the phone with Classic Performance Parts and they told me to get a 1971-72 3/4t disc brake master cylinder and their proportioning valve and use my 69 3/4t booster and I'll be set for disc brakes.They also said to run the lines front res to front on valve and rear res to rear of valve. NOW I AM REALLY CONFUSED!!
02-11-2007, 04:01 PM | #20 |
Here we go again! I just came back from the auto parts store to get a m/c.I looked up a 1971-72 c20 with disc brakes to go with my 1969 booster and brackets-NOT GOING TO WORK! the m/c has a shallow piston and the booster to m/c rod is long.What am I doing wrong here? This is what I have: 1969 C20 2wd booster and brackets(dual diaphram) and want to add disc brakes using these parts to my 1969 C10 2wd with manual drums. Please tell me what I am dooing wrong!?Thank You in advance
-Lance |
