02-04-2007, 08:21 PM | #1 |
Junior Member
carb rebuilding
reassembly phase of rebuilding my qjet, and i finally ran into a problem. midway thru reassembly, i realized that the fuel discharge ball never came out. upon inspection as to why, its because there is a little ring of rust holding the bastard in!
what on earth do i do to get it out?? |
02-04-2007, 08:26 PM | #2 |
Re: carb rebuilding
compressed air
02-04-2007, 08:48 PM | #3 |
Junior Member
Re: carb rebuilding
ohhhhhhhhhhhh yeah, i guess that makes sense. i guess ill take it with me to work tomorrow, and stop off at the goodyear and see if the fellas there might blow it out for me.
02-04-2007, 08:50 PM | #4 |
laying low
Re: carb rebuilding
Little hit of wd 40, let it sit and blow it out with air. Keep your eyes on that little ball though, through safety goggles that is.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
02-04-2007, 10:18 PM | #5 |
Re: carb rebuilding
a needle held with needle nose plyers to scrape the rust away after letting it set overnight with wd40
02-05-2007, 11:58 AM | #6 |
Junior Member
Re: carb rebuilding
well that ball blew right out on the first shot! whew! i was getting a little worried that i was going to be buying a new carb over a tiny rusted metal ball!
hopefully today ill have time to finish the reassembly, and try it out on the truck! |
02-05-2007, 10:24 PM | #7 |
Junior Member
Re: carb rebuilding
SHE RUNS!!!!
i just put the carb back on, and she fired up on the first crank!!! im astounded that i rebuild a qjet on my first try, but i feel like ive passed a litmus test, and i DO have what it takes to restore a vehicle! now i just need to figure out how to smooth her out, and ill be able to drive around a bit. i had some trouble with the secondaries intake flaps, but i found a carb shop about 3 miles from my apt, and they had a ton of qjets laying around. they wernt really in the spare parts business, but i talked the guy out of a spring-return for the secondaries, for $5 (i needed it, and i wanted to make sure i left with it!). i actually had it on and running earlier today, but with the secondaries stuck open. it would fire, but would only run wide open and then die when i let off. now, it starts and almost idles, but then dies. i need to so some reading on what to do with the mixtures, and then im set! |
02-05-2007, 10:30 PM | #8 |
In Memoriam...
Re: carb rebuilding
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
02-05-2007, 10:37 PM | #9 |
Re: carb rebuilding
plus check the play in the throttle shafts........they are vacumm leaks when they are worn
02-05-2007, 10:40 PM | #10 |
River life......
Re: carb rebuilding
Nice, it definitely feels good to make some headway.
02-05-2007, 10:46 PM | #11 |
Junior Member
Re: carb rebuilding
thats EXACTLY the way i feel right now!! i celebrated by running down to the autoparts store and picking up a chrome 14" air cleaner
02-07-2007, 09:45 PM | #12 |
Junior Member
Re: carb rebuilding
just had me another parking lot celebration, because i got her tuned close enough to roll without dying!!!
