Old 02-05-2007, 10:33 AM   #1
timcos
Chief Honcho In Charge
timcos's Avatar
Leaning Tower of Chevy
OK...I put the truck in the garage. Doing the heater core thing.
This morning, as I parked my other car behind it I noticed the left front of the truck is leaning. I could really tell because the roof was not parallel with the ceiling in the garage. I initially thought the tire had lost some air. It did not. I have only had the truck for about 6 months and did not really notice this before...that does not mean it was like this..I just did not notice or had a reference.
So I did some quick measurements. 28.5 inches to the top of each front tire. But the fender wheel well measure 35.25 one the left (driver's) and 37 on the right.
Could a shock be stuck on the right and pushig that side up? Could something have collapsed on the left side?
I am gong to get underneath it this evening and see if I can find where the problem is. I have to finished the heater core thing anyway.
What think YE?
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 02-05-2007, 10:37 AM   #2
cdowns
cdowns's Avatar
Re: Leaning Tower of Chevy
did you check to see if both tires are the same size?? not uncommon for left side springs to sag more than right side especially if there's been a fatass driving for 35years
Old 02-05-2007, 10:39 AM   #3
timcos
timcos's Avatar
Yes,
28.5 inches to the top of each tire.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 02-05-2007, 10:47 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
You might have a broken or damaged spring.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-05-2007, 11:40 AM   #5
RedZ71
Junior Member
RedZ71's Avatar
does your shock on one side... look like this??
http://www.dfwlp.org/~jhorne/pics/tr.../dsc06197.html
(mine leans too!) hehe
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 02-05-2007, 11:43 AM   #6
I hope it`s not a sink hole.
Old 02-05-2007, 12:38 PM   #7
timcos
timcos's Avatar
That is the funniest engineering for a shock I have ever seen.
No...mine does not look like that...LOL
I did glance at the springs on the way out...and they are bowed in an upward direction with the ends being downturned...but both are like that...it did seem to me that the driver side leaf was more bowed...I could not see a break...but I did not look closely enough I am sure.
Mine has two leafs. If I get the one at NAPA for 189 that has 5 leafs...did I just screw up...or make it a 3/4 ton?.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 02-05-2007, 01:25 PM   #8
bad_turbo
turbo enthusiast
bad_turbo's Avatar
I see you stated "leafsprings", so I'm guessing its a 4x4? My '69 1 ton has coils on the front that are worn out and sagging, so whenever I take a corner the truck will keep leaning that way til I turn the opposite way. Springs are just worn out.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 02-05-2007, 01:42 PM   #9
timcos
timcos's Avatar
Yes...K10...leafs on front and rear.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 02-05-2007, 11:05 PM   #10
pritch
pritch's Avatar
Hey Tim, you might call Triple A spring in Salt Lake-they did me a real good job on some overloads on a f*rd I had a while back. Fairly inexpensive, too. I was expecting a lot more than they charged. Their # is 801-972-1359. Address is 995W 2900S.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 02-05-2007, 11:22 PM   #11
skchevota
skchevota's Avatar
Check the rear ( rear of the front spring) shackle and see if the bushings are still there, including the ones in the frame.
skchevota is offline   Reply With Quote
Old 02-06-2007, 12:15 AM   #12
timcos
timcos's Avatar
Not sure if I am refined enough mechanically to notice the bushings...and whether or not they are there.
I will most likely go see the place pritch recommends
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 02-06-2007, 12:26 AM   #13
Fastfun
Fastfun's Avatar
Could bad body mounts cause the leaning also?
Fastfun is offline   Reply With Quote
Old 02-11-2007, 12:46 AM   #14
timcos
timcos's Avatar
OK...I just did some measureing...the bed (measured at the apex of the wheel well) is 1 inch lower on the driver side.
The front wheel well is 1.5 inches lower on the driver side.
Tires are all same height.
Could this simply be because 1 guy weighing about 175 mostly drove this truck for 33 years?
Could that have worn the springs on one side?
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 02-11-2007, 01:25 AM   #15
Sammy
Don't get too excited about the lean. My Fathers 70 4X4 leaned real bad inside the garage front & rear after putting new tires on. Drove it outside everything seated in the suspension and measured it leveled out. So if you jacked it up it may just need to level out.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-16-2007, 01:18 PM   #16
timcos
timcos's Avatar
My rear springs are arced in the downward direction (like a smile)...the ends of the leafs going up.
The front springs are arced upward (like a frown with the ends slightly pointing down).....left and right are both arced in this manner...
Does not look right to me.
Is this correct...or are my fronts work out and that is why the truck is leaning...nothing looks broken.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 02-16-2007, 01:28 PM   #17
manimal
manimal's Avatar
As skchevota said look at the rear shackle on the front leafs the bolts should be in the center of the bushings.If not then you have bad bushings-VERY common,especially in the frame brackets. use urethane for replacements,they wont sag.JMO
-Lance
manimal is offline   Reply With Quote
Old 02-16-2007, 01:40 PM   #18
timcos
timcos's Avatar
I could not imagine only a bushing would make the leafs point in the other direction,..
I guess my question is...which direction should the leafs be bending or formed?
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 02-16-2007, 02:46 PM   #19
manimal
manimal's Avatar
All the 1/2t and 3/4t 4x4's I have had with stock leaf springs were "DE-ARCHED" but most only had 2-3 leafs anyway. If the bushings are worn or 'gone' on one side,you could easily loose an inch or more. To replace your front springs,it would be about the same to put a small lift on it and run a slightly larger tire. say a 4" with 33's.JMO- Good luck
-Lance
Old 02-16-2007, 03:52 PM   #20
timcos
timcos's Avatar
I went to AAA spring in Salt Lake. ~$360 for new 3-leaf leaf springs (both sides) and about 80 bucks worth of new parts like bolts, bushings, shackles, etc. The fellow said they were definitely worn. He did say that GM put these de-arched springs on the front end for a few years to give a nice ride for the trucks...he also said it did not work too well.
Should I do this job myself?
They will do it for a little more than 200 on top of the parts.
I have air tools, 3 ton jack, jack stands, and a lot of spit and vinegar.
These things look like lots of bolts and bushings...any FAQs just to guide me?
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 02-16-2007, 04:39 PM   #21
timcos
timcos's Avatar
I just checked with Big O...they will do the whole thing for $480.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 02-16-2007, 04:40 PM   #22
timcos
timcos's Avatar
I am really biased toward stock height. I love the big lifts and large tires...I just do not want to drive one daily.
-Lance
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 02-16-2007, 08:30 PM   #23
timcos
timcos's Avatar
ttt
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 02-16-2007, 09:03 PM   #24
Jtrux
I'm a poor spectator
Jtrux's Avatar
Take your time and make sure the truck is on a flat surface and the parking brake is on. Lift the truck by the frame ( will have to use blocks cuz it's pretty high) and bring it to the point where the suspension is maxed out but not lifting the tires off the ground and remove the U-bolts from the axle. Oh, take the shocks off too. With U-bolts disconnected lift the truck further up and the spings should raise up off the axle. Then take the springs off and put it all back together. Always use new U-bolts, NO EXEPTIONS! They torque to yield and cannot be used over and over again.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 02-20-2007, 09:08 PM   #25
timcos
timcos's Avatar
The new leafs are in...or is that leaves?
It even out the truck...and it raised the front end about an inch or a little more...now it is sitting level from front to rear.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
