Old 02-05-2007, 06:54 PM   #1
alec22
holley carb & detent cable hookup
I put a much needed new carb on today. I was able to get the throttle adapter and cable hooked up, but I'm clueless on the detent cable (TH350). As far as I know I may not even have the right cable on there. Does anyone have any pictures of this type of setup? Also, what part #'s did you use for adapters or brackets? Thanks!
alec22 is offline   Reply With Quote
Old 02-05-2007, 11:10 PM   #2
ureckme
ureckmefixit2@cox.net
Re: holley carb & detent cable hookup
I used my stock bracket but spaced it up 1/2 inch.
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 02-06-2007, 12:28 AM   #3
alec22
I've been looking at detent cables, and I think I may have the wrong one installed. The cable I have has the linkage end that is open. Meaning it can move about an inch or so. I've seen pictures of linkage ends that pop onto a ball type stud that is bolted to the linkage. The one that pops onto the ball seems like it should be the cable that is on my '85, but I really don't know.
Old 02-06-2007, 11:03 PM   #4
fourty1
fourty1's Avatar
Guys try :
LMC ( page 43 )
or
YEARONE
here's a page from LMC
1941 Chevy 1/2 ton Street Rod: 327 cu,/350 auto, 'Stinger ' - JULY 2007 CUSTOM CLASSIC TRUCK magazine.
1967 Chevy 3/4 ton standard bed, 350 cu./400 auto,
w/ 83 - 3:43 rear end...sips gas....
fourty1 is offline   Reply With Quote
