Old 02-05-2007, 07:43 PM   #1
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
Leak: What is it? Why? How do I fix it?
Ok well I think its transmission fluid, how do I stop it from leaking? It isnt a bad leak, I wiped it down yesterday and so far all that has formed so far is what you see there, it has not dripped yet.
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 02-05-2007, 08:42 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Re: Leak: What is it? Why? How do I fix it?
That's the speedometer cable. You fix it by putting in a new seal. Unscrew the cable and you will see the seal.
Oops. Forgot to say it might just be loose too.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-05-2007, 08:47 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
There is a small seal inside that speedo gear-head housing. The easiest way is jack the rear of the truck high and remove the cable then the gear-head housing. Slide the gear out of the housing then stick a small screw driver in place of the gear pushing the seal out. Be careful because there is a small wire ring holding the seal in place on the outside.
They do have tools to remove and re-install this seal without removing the gear-head housing but they are a bit expensive.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
