Old 02-05-2007, 10:44 PM   #1
DennisL
Question Is this a 68 or 71 Chev?
Hi, to all the members. I just bought a 68 or maybe a 71 Chev? I'm not sure which exactly. The title says 68 Chev, but the VIN as decoded was 71. The metal VIN # has been replaced and all the paperwork agrees, as far as 68 model and the 1971 VIN # which is odd. I think it was probably wrecked years ago, and a 71 GMC front end was put on and the VIN was changed then to reflect that or hide the fact it was salvage titled. The VIN tag is rivited on, but it doesn't say from what state. I can tell it came into Calif. in 2004 from the title. In any case it has the 68 "Custom Cab" plate on the outside of the door. The truck has drum brakes on the front. It has a 64-66 or so steering wheel which is on a factory tilt colum, (I was raised driving a 64 so I know what the steering wheel looks like), It has the big emergency brake handle like the 64 did, only its chrome plated, it's under the steering wheel and is a big lever. It has a V8 with 3 speed auto and a factory tachometer which still works. It appears to have the 68 door upholsstery on it which is embossed and cover approx. the middle section of the door. I think its a 68 because of the drum brakes and emergency brake.
DennisL is offline   Reply With Quote
Old 02-05-2007, 10:54 PM   #2
Idaho Outlaw
Idaho Outlaw's Avatar
Re: Is this a 68 or 71 Chev?
Does the front clip look like a 67-68 or a 69-72? Everything you describe would make me think 68 except for the Vin decoding. Are you sure you decoded it correctly?
1972 Chevy LWB K10 Custom/Deluxe
Earth first! We'll log the other planet's later.
Idaho Outlaw is offline   Reply With Quote
Old 02-05-2007, 10:57 PM   #3
1969k10stepside
If it has drums,it is atleast no newer than a 70,atleast the chassis most likely is
1969k10stepside is offline   Reply With Quote
Old 02-05-2007, 11:10 PM   #4
krue
Designated A-hole!
krue's Avatar
No telling, these trucks are so easy to mix and match parts off of. Sounds like a 68 chassis to me (71 would have disc brakes up front).
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-05-2007, 11:13 PM   #5
bad_turbo
turbo enthusiast
bad_turbo's Avatar
somebody probably swapped out cabs
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 02-05-2007, 11:19 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
to the board.... . Swapped cabs and took the plate off of the old cab.
LockDoc
Leon
Old 02-06-2007, 01:42 AM   #7
68shortfleet
Curious what VIN is stamped into the frame. It's on the top of the left frame rail right behind where the steering gearbox is. Does is match the title? What shape are the heads of the rivots that hold the cab VIN on? Round? or kinda six sided(have to look close to see)?
Jason
68shortfleet is offline   Reply With Quote
Old 02-06-2007, 01:54 AM   #8
bigblockorange
hey dude I bought a 67 truck titled as a 71 it was a dealers parts truck years ago and when they solded it, it was title as a 71 Pendot went nuts in the end they just changed the year to match the truck took some time but with a 67 you can't hide the small window. Rob
bigblockorange is offline   Reply With Quote
Old 02-06-2007, 07:32 AM   #9
Is the VIN-plate factory or a DMV one?Are you talking about the one in the door jamb?The VIN# is also on the left frame rail top flange.The tilt column is`69-up.The steering wheel sounds like a 67/68 as well as the brake lever.The dash should have a manual choke location,too.
Old 02-06-2007, 08:13 AM   #10
DennisL
I'll have to check the frame rail for another ID. It has the dual GMC headlights and no patchwork of wiring, it all looks factory so they did a lot of work. Also found out lastnight as I was looking at the title it was brought into California in 2004.
Old 02-06-2007, 10:03 AM   #11
They prolly just used the underhood harness from the GMC donor.It`s just a plug at the firewall.Most likely you`ll find you just have a front clip from a`71 GMC on a`68 Chevy and the`71 GMC VIN-plate was used.Yet,it`s titled as the`68 still.You can`t get this straight with the previous owner?The`71 VIN# will not detect a Chevy or GMC w/o looking deeper into the numbers.
Old 02-06-2007, 04:59 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
actually, if you try to decode a GMC vin on a chevy decoder, you'll be confused and scratching your head.
Can you post your VIN... leaving off the last 5 numbers if you feel threatened that some one will steel your trucks ID.
The one problem you'll have, is the Republic of Cali will give you a REAL hard time if your stuff ain't right.
Old 02-08-2007, 09:39 PM   #13
DennisL
Thanks for the welcome I've got some pictures of the truck that I took, I'll see about getting them on here. I did look for another vin on the frame and its the same vin for a 71. I looked at the vin tag on the door frame and its a replacement by California Bureau of Automotive repair. So I think the truck is a 71 and I guess the 68 for the model year is just a mistake for who knows how long.
Old 02-08-2007, 09:55 PM   #14
DennisL
hopefully I can post the pictures on here.
Old 02-08-2007, 10:06 PM   #15
Troy-Built
That looks to be a 71 up GMC grille since the accents in the grille are black. I like how they frenched the 66 or 7 nova tailights in the fenders. Looks to be a real nice truck.
69 Chevelle SS 375/396 TKO 600
71 Suburban 3/4 4x4 402 5-speed (project)
68 chevy C10 shortbed 327 5-speed (project)
72 Blazer 4x4 400 4-speed (wifes project)
Numerous 67-72 parts trucks
Troy-Built is offline   Reply With Quote
Old 02-09-2007, 01:32 AM   #16
LockDoc
LockDoc's Avatar
Man, I like that truck!!!! I guess I'm just a sucker for white.... Looks like you could just buff it out and drive it. I would....
LockDoc
Leon
