NOT REALLY BANNED!
![]() Join Date: Jul 2004
Final Tranny Swap ?'s
If I use this crossmember:
http://www.classicparts.com/prodinfo.asp?number=79-507 And a TH350 with a short (READ: 6") tailshaft, it'll work with my stock driveshaft, that was originally hooked up to my 3speed manual? I just want to make sure before I start buying things.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
NOT REALLY BANNED!
Re: Final Tranny Swap ?'s
ttt
The location of the tranny cross has nothing to do with the length of your tranny tail-shaft, only the mount points on the frame. You may have to drill new hole to mount your new crossmember but what you should ask:
Is the Th350 with the 6" tail the same length as stock 3sp? Got a tape measure and both trannys handy? Last edited by Americanrider; 02-06-2007 at 04:04 AM. |
#4 | |
NOT REALLY BANNED!
I'm not asking about the location of the crossmember, i'm asking about driveshaft issues.
Yes....I did the swap. It is no problem, you can use the 3 speed driveshaft with no mods. providing you get a short tail TH350 to put in it's place.
'72 Custom/10 SWB project... converting to 4WD '67 Camaro rs convertible...waiting in line '99 Ext. Cab Z-71 190000 miles on orig. trans fluid '02 Black Z-71 burb..(wife's) '92 Accord (daughter's)....Who want's my insurance bill? |
