Old 02-05-2007, 11:44 PM   #1
BowTieOgre
Gauge Issues
My old guage cluster lights didnt work and the volt meter and engine temp guage didnt function at all so I picked up a newer guage cluster. I installed it and hooked everything back up and now the lights work but the mech. OIL guage is pegged out at idle and the volt meter just sits there straight up no matter what. Ive just about lost my temper with this things having removed and reinstalled it about 12 times...anyone have similar issues or suggestions?
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 02-06-2007, 01:49 AM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: Gauge Issues
BowTie-
If I remember correctly, I don't believe the volt gauges from later-style custers are interchangeable with those of the early-style custers (voltage-sensing vs. current-sensing). I think it's the oil pressure gauges are not interchangeable as well. Maybe, the issue is the sensors.
But, again I'm not sure ...
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 02-06-2007, 10:02 AM   #3
BowTieOgre
Re: Gauge Issues
I forgot to mention that when I hooked the "new" cluster up the oil gauge was not working up to specs so I replaced it with the one that was in the factory cluster. THEN the factory gauge would not work right, kept reading 55-60 at idle. The other day it actually read 15-20 but then jumped right back to 60 the next time I drove it. I guess I will just end up popping for some Autometer gauges and call it a day!
Old 02-06-2007, 12:36 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Gauge Issues
what year truck are we working on?
what year did the cluster come out of?
Is the engine/oilpump factory?
Are you expecting the volt meter to move? It should stay around 13.7v.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-06-2007, 03:04 PM   #5
BowTieOgre
Re: Gauge Issues
It is a '73 and the replacement cluster came out of a '79 I believe (bought it off a board member). The motor is a stock 350 4bbl and as far as I know everything is original. The only things I have done to it are change all the fluids/filters, install an HEI dizzy and plug wires and replace the starter. Thanks for the reply CK.
Kris
Old 02-06-2007, 03:51 PM   #6
Captkaos
Captkaos's Avatar
Re: Gauge Issues
You are running a risk putting anything other than a 73-75 cluster in a 73.
The 73-75 model was AMPS not Volts so they are wired different. Meltdowns are typical if you swap to a non AMPS dash and plug it in.
the 78-up cluster uses all electrical senders, and you have to have the correct sender to make it work.
If yours has a mechanical oil pressure guage and a volt guage it can ONLY be a 76-77 model. Again, 73's are wires for AMPS, the oil sending should be ok if you got all of it from the donor. Where are you tying into the engine?
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 02-06-2007, 09:49 PM   #7
tkeduk8r
tkeduk8r's Avatar
Re: Gauge Issues
Amen to what chris said.. you NEED a 73-75 cluster!!! There are other ways to do it, but that would be the easiest/least hassle...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 02-07-2007, 01:20 AM   #8
BowTieOgre
Re: Gauge Issues
--Mike
And so the hunt begins.
Old 02-07-2007, 02:50 AM   #9
Russell
Professional Grade
Russell's Avatar
Re: Gauge Issues
Lemme check in my parts pile... I might still have a 73-75 cluster kickin' around out there... If not, I know there is one at the wreckers. I can ship you the whole mess for the cost of shipping if I've got one, or the cost of shipping + the cost from the wreckers if I don't.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-07-2007, 09:39 AM   #10
BowTieOgre
Re: Gauge Issues
You've got yourself a deal Russel! Ive hit the yards here and its slim pickings on the 73-80 body styles and 73-75 Blazers are even more scarce. Any parts you guys can send my way will be much appreciated.
I went to the store last night and the oil gauge started working properly...go figure. If current trends hold it will be jacked up the next time i drive it tho.
Kris
Old 02-09-2007, 08:03 PM   #11
Russell
Professional Grade
Russell's Avatar
Re: Gauge Issues
Just letting you know -- I haven't forgotten about you, just haven't had the opportunity to hit the wreckers yet, I'm hoping to make it out on Sunday afternoon.
Old 02-14-2007, 01:17 AM   #12
Russell
Professional Grade
Russell's Avatar
Re: Gauge Issues
Ok, I swung by the yard and didn't see any 73 - 75 clusters... I'll take a look at the other yard later on this week when things warm up a bit again.
