Old 02-06-2007, 12:19 AM   #1
skokie
skokie's Avatar
Need help with engine pullout
I am going to be pulling the 350 out of my 68 to change out the flexplate and a few other things. Now I have never pulled an engine by myself. I am going to be renting a cherry picker and getting a old tire or 2 to sit the engine on while I work on it and the engine bay of the truck.
Beside's unhooking everything attached to the engine is there anything I need to be careful of or need to know? Is this a 1 man job or should I get some help? The grill, radiator support, drivers side fender are off. The hood will be to before I do this.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-06-2007, 12:34 AM   #2
skchevota
skchevota's Avatar
Re: Need help with engine pullout
Sounds like your good to go, be carefull. are you on flat ground, that engine will get away from you real easy if your on a sloped drive. What part of San Ho are you in. Ive got a good buddy that lives off Branham and Montery that I can call if you get in a Jam. He has a nice 70Nova with an LT1, hes always looking to get his hands on a hotrod.
skchevota is offline   Reply With Quote
Old 02-06-2007, 12:40 AM   #3
skokie
skokie's Avatar
Im over in South San Jose. The truck is 2-3 feet from the garage. Thanks for the offer. A neighbor of mine is the same way, cant wait to get into a engine
68 build thread
Old 02-06-2007, 01:02 AM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
It's definitely a one man job...depending on who you talk to. I say tear it out on your own, that way you know every little thing that came off and goes on. Some people prefer help, either way it is a very doable one man job, however, putting it back in will require a little more patience with one person but since yours is an auto it should make things easier.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 02-06-2007, 01:02 AM   #5
brak
brak's Avatar
i've pulled several motors by myself.
just go slow, and check everything two or three times, and it'll be over before you know it.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 02-06-2007, 01:15 AM   #6
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
My .02 if this is your first engine pull ya might want to pull the distributer. I personlly always pull it and I have done many. Really easy to slip and break it
If your not sure on the timing pull the cap mark all wires mark were the rotor is pointing on the engine agood idea is to bump the engine over with the cap off to get it to a good memoarable spot (strait at back of carb for example)
then pull. dont use a spot on the dist. housing as this will turn. after the engine is out replace before working on flex plate as engine will turn during this process. Right befor going back in reverse these steps. sorry if you already new this just trying to help, and save some headach if you make a slip
just remember if the engine turns while the dist. is out follow steps to put the dist. back in time theresthreads on this subject here but if you can't find one just ask someone here will talk you through it myself included
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 02-06-2007, 01:28 AM   #7
GREASEMONKEY72
GREASEMONKEY72's Avatar
sounds like you got it but it doesnt hurt to have a buddy there just incase (learned that the hard way) but goodluck with it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-06-2007, 01:32 AM   #8
65-72 chevytoys
65-72 chevytoys's Avatar
If you don't pull the trans out with it. Make sure you support the front of the trans bellhousing and disconnect the flexplate to torque converter bolts. If it does not come out easy check again to make sure something is not still hooked up. A cherr picker is used to test the tensile strength of anything still connected.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
