04-24-2002, 11:20 AM | #1 |
Location: Bondurant, IA but in Worcester, MA for school
C notch????
I want to drop my 1970 C-20 in the rear about 5 inches with drop leaf springs mabe go to 6 inches with shackles. My question is do I need to put a C notch in??? Any help would greatly be apreciated. Thanks
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
04-24-2002, 11:29 AM | #2 |
You should be able to get by with a 5" drop,& no notch.....if you dont plan on hauling. I think a 6" drop will bottom without the notch.......69 longhorn
http://community.webshots.com/user/hotrodhorn |
04-24-2002, 11:40 AM | #3 |
How hard is it to install a C notch?
04-24-2002, 11:52 AM | #4 |
Got 20's????
If you remove the rubber bumpers after a flip kit you will have about 1/4" space between the axle and the frame, so you do need to do the c-notch. All thats to the c-notch is cutting the hole in the frame and bolting on the notch.
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
04-24-2002, 11:57 AM | #5 |
I havent installed 1 , but from install pics,it doesnt look too bad. I have a 5" drop on the longhorn(flipped axle,& relocated stock spring brackets,& removed 2 leafs & the flat helper). I have between 3 to 3 1/2 " clearance tween the axle & frame(no bump stops), & havent bottomed anything......69.
04-24-2002, 01:07 PM | #6 |
aka Crusher, Crushergmc
Go to the suspension board and check out the C notch topic. I pulled it up for ya.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
04-25-2002, 03:00 PM | #7 |
Can you cut the c-notch with a torch? If not how do you do it? Thanks
04-25-2002, 04:00 PM | #8 |
Progress = 0%
Cutting torch, saw-zal, electric grinder with cut-off wheel, etc.
------------------ Current project: The "HACKstoration" 1967 GMC shortbed/fleetside, 350/700R4, air bag suspension, 18" billet wheels. Other vehicle of interest: 1957 Chevy Bel-Air 4dr hard top, 283/powerglide, lowered 3-1/2" in front and 2 inches in the rear. Web Site: jaySpot.com AOL Screen Name: Slammed67GMC Location: Kansas City, MO
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
