Show me your Mig Welds!!!
I finally got gas for the Lincoln Promig 135. I started playing around with it and the welds look 100% better. At first they didn't improve much, but then I realized I was using the wrong tip diffuser thing. I changed that out and now the welds look like smooth snakes, not really a roll of coins though.I did a butt weld on a couple of scrap pieces and I think it looks good, but I would like to see your welds to make sure mine looks close. So can y'all show me some good Mig welds with gas before grinding smooth? I appreciate it!!
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Re: Show me your Mig Welds!!!
What tip diffuser thing? I can't weld worth crap no matter what I do, but I keep trying. If I knew what it was maybe I could change mine too. Probably wouldn't help my skills.
![]() Join Date: Dec 2006
take a roll of dimes and fold them over and that is what my welds look like.
with mig it doesnt look like a roll of coins most of the time unles you weld with short bursts its like half a sec on the spot move a little and zap again half a second
a continuous weld looks just like that a continuous weld if its the same bead and it has penetration all the way through the metal youre doing a good job the famous coins are more a tig weld thing where you can add filler rod and vary youre output
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
heres some goofy head stands i just made not a lot of welding
On the fast track to nowhere..
Here are a couple shots of the welds on my crossmember section. I didn't spend a lot of time cause no one is gonna see it anyhow. And, a pic of digger just for good measure. Bet there's some good welds on that sucker!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
mine looks like bird poop! after eating berries!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
the roll of coin weld isnt just for tig, but with the gas mig or flexcore mig my welds look like a roll of coins how much like it does vary and it also varies on the aplication its doesnt always HAVE to be a roll of coins as long as you have good penetration its good i personaly think the roll of coins looks cool so i do it alot but its not needed
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
I could never get a real good weld with my 135. Bought the new 175 and love it.
#13 |
I'll have some soon when I get my gas
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#14 |
Here is the only few I got done before I left to pick up my little one from school:
The one on the left is one with gas, but the wrong diffuser thing. I changed it and got the weld on the right. ![]() THis is an up close of the weld on the right: ![]() Here is the backside of the one on the right side (the one I think is okay). THe weld doesn't look like it goes all the way through, but it almst does.. ![]() I know I need more practice, but am I on the right track with the one on the right? How do I get the weld to go a little deeper on that one? I am at the max voltage. Do I just slow the feed and stay on spot a little longer? Thanks for the advice. Also, what should my gas pressure be at? I've got it set at 15 psi right now, is that right? Shawn
#15 |
Or it looks like where a coon took a sh#t on a log and walked through it backwards. Thats what my shop teacher used to tell me.
Kevin 1967 C-10 swb fleetside 1968 C-10 stepside 1999 Z71- sons dd 1999 2wd silverado-my dd 2003 Tahoe- wifes dd |
#16 |
jorgensensc slow down! your crown is too high and you have arrows instead of snake belly's. your on the right track. you might want to play with your wire speed a little.
#17 |
GEARHEAD
You will search far and wide to find welds any better than PORTERBUILT lays down. Search some of his threads and you can set you goals high and strive for his level of performance. That is coming from a circle track guy that has seen alot of welds. I only wish to have welds as nice as his someday. I'm sure alot of guys on here will agree. Looks like your on the right track though practice makes better because no one is perfect.
#18 |
yup porterbild and trepanier from rad rides have allmost the same welds its allmost spooky
#19 |
![]() Join Date: Feb 2007
No beads on this picture. But good penetration. This is my homemade Chevelle flatbottomed floor. Welder made a big difference. Started with an Italian MIG that was really inconsistent with the temperature. Got a cheap German welder and saw a big improvement.
#20 |
#21 |
I thought Nathan's work was all (or mostly) Tig. You are right about his welds, though. A thing of beauty to behold.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#22 | |
"Taste It"
Looks to me that you are a little hot and not enough wire feed??? too much spatter. this can also be controlled by arc length (wire stickout from the contact tip) too much you'll get spatter. I've always set my welders by the sound. I'll set my heat to the material thickness then match my wire speed for the sound I'm looking for. It helps to have been welding for a living for 18 yrs. If you're doing spray transfer it should hiss, if you're doing short arc it should buzz The way I usually start setting my welder is say my welding heat setting is 5 I'll set my wire feed at 60 Also if you really want nice clean welds take a second w/ agrinder and clean the surface you're going to weld (take the scale off) just make it shiny no gouging just a quick swipe. If you've any more questions feel free to post I'd be happy to help,that goes for anyone (I'm not an expert but I did sleep at a Holiday Inn Express) I've become a desk jockey and truly miss being in the shop. I've built everything from food processing equip, to cell towers,buildings and lots of custom aggregate processing equip (huge stuff) and lots of stuff in between. Hope this helped Brian
71 Chevrolet short fleet Cheyenne air cab/tilt w buddy buckets pretty stock other wise. ![]() ![]() 2007 Silverado Crew with the MAX Pack and loaded 2007 CX-9 "Hopefully when I die.. my wife wont sell my stuff for what I said I paid for it" It's easier to ask forgiveness than it is to ask permission. ![]() |
#23 |
the sound youre looking for when welding mig is the sound of eggs and bacon frying in a pan not realy spattering but more sizling
#24 |
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
#25 |
soon to be bagged64sub
This is the pic I have handy of a recent weld. It was done with a miller 175.It is the plate on the side of my frame where I Zd it.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
