02-06-2007, 08:54 PM | #1 |
Need help!!
I am going to look at a 71 Long bed P/U this weekend. It is bone stock w/ 307 and 3 on the tree.Pretty clean from pics. Guy said it has some rust in rockers and bed floor but that's it???I could use some help on what problem areas I should be looking for on this truck. I am very familiar with the 73-87's but not the 67-72's. Any suggestions? Thanks in adavance for any advice given!!
02-06-2007, 10:24 PM | #2 |
Re: Need help!!
Along with the rockers, check cab corners, front/rear cab supports, around the windshield, the ridge underhood where the wiring harness runs, look in the cowl, check the floor and kick panels. Hopefully it's nice enough to buy!
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
02-06-2007, 10:33 PM | #3 |
Dave's not here, man
Re: Need help!!
Cab corners, cab supports, rocker panels. Those are usually "problem" areas for these trucks. I'm sure others will chime in with additional info.
I was too slow.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 02-06-2007 at 10:36 PM. |
02-07-2007, 03:42 PM | #4 |
Re: Need help!!
This is a good start.Thanks
02-07-2007, 03:52 PM | #5 |
Re: Need help!!
Don't be afraid to climb completely under the truck to get a good look at the floor panels, and cab supports.
mini maglite, and a screwdriver will be your best friends ")
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
02-07-2007, 04:00 PM | #6 |
Re: Need help!!
check the corners of the truck bed closest to the cab and in the bed around the wheel wells. Check the rear of the bed closset to the tail gate corners.
