Steel Horse Cowboy
Where to get new brake lines (LWB with rear leafs)
I'm trying to find a set of all new pre-bent lines for my 68 gmc but I can't seem to find any, LMC has a set but they say the won't work with trucks with rear aux leafs. When I complete the project it will be front disc/rear drum and I wanted to do all the lines at that time, anyone know where I can get em?
#2 | |||
Union Electrician
Re: Where to get new brake lines (LWB with rear leafs)
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
![]() Join Date: Nov 2005
Byrd is right. I had good luck with Inline Tube.
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts! |
Active Member
Is there any reason why a guy would want to switch to Stainless? Thinking about replaceing lines in my 67 while I got it apart, and was wondering.
Also, I am converting to discs in the front, what year lines should I get? The rotors adn calipers are off a 76 but then it ECE dropped spindles and all 67 from there in. Thanks
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
Same here go with inline tube. Mine came from them and they fit great.
kevincar- Stainless dont rust and brake lines are bad at rusting thru, that is why mine got replaced. They rust both inside out and outside in. I think they have a specila kit for those with 67-70 that have been converted to discs. If you cant find that then just get the 71-72 front line set and reuse your existing front to rear brake line. Hope this helps. |
Steel Horse Cowboy
Thanks for info guys, I was looking around at inline and found the disc brake conversion lines for 67-70 but it does'nt say if to works with rear leafs... maybe I should just call?
#7 | |||
Union Electrician
Yeah do that, they are GREAT to work with and will make sure you get what you need. I bought my e brake cables in stainless from them, and I wish I would have found them before I got my brake lines from the truck shop. Inline would have been cheaper in the long run and the best part they make all their parts, in AMERICA not like the truck shop
![]() Join Date: Mar 2004
make your own! it's cheaper faster and you can route them how you like. use a peice of wire coat hangger to moc up what you want it to look like then bend the pipe to match. yes it will take a little while but you'll enjoy it i promiss.
Steel Horse Cowboy
I've actually done that before, did a set for a friends old ford, and your right its really only a time factor. That's really the only reason I'm not doing it for myself this time around, not alot of freetime, and want to get this truck daily driving quickly.
