Old 02-06-2007, 09:08 PM   #1
st1x10
st1x10's Avatar
Help with a bolt.
I was trying to remove a bolt from the bumper, but the hole is stripped out. Anybody got any ideas??
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 02-06-2007, 09:28 PM   #2
67cst
i love summertime
67cst's Avatar
Re: Help with a bolt.
you trying to save the bumper or just get it off? ive had that problem in the past, im sure lots of guys on here have as well, what ive done is get a cut off wheel on a grinder and just start cutting, it will gouge the bumper a bit though but i was junking the bumper anyways.i guess if your trying to get it off without f'ing up your bumper you could start with a smaller drill bit like 3/16" or so and drill out right through the center, ive done think on frame rivets that i couldnt get at with a grinder and that will crill the bolt side right out and eventually get the bolt off, it might be a bit time comsuming though
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 02-06-2007, 09:31 PM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
my rear bumper had one like that so i took the bracket off with it and with some work i was able to get it losse enough and i welded the bolt to the bumper and was able to get the nut off then i welded it up and welded the others to and put it back on
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-06-2007, 09:31 PM   #4
kxnomore
kxnomore's Avatar
I was able to tighten a bolt with a large breaker bar until it broke off. Just a thought.
kxnomore is offline   Reply With Quote
Old 02-06-2007, 09:43 PM   #5
st1x10
st1x10's Avatar
Hmm, Yea I really don't care about the bumper it is all tore up anyways. The cutoff wheel might work. Thanks.
2002 Chevy S10 V6
