Old 02-06-2007, 11:06 PM   #1
smoknbarrels
Registered Mail
smoknbarrels's Avatar
What is the best cruising RPM ?? I need a good rear ratio and tranny!
Hi, I have some problems with tranny and rear selection..
I have been trying to cut corners and determine a tranny that will hold up to my moderate perf 454, it has lots of cam and I will be going with a standard tranny..
I have been looking at Tremec 6 speeds, all the gears are great ratios until the 6th.. it is 0.50. so with my 29 inch tall tires I will only be doing 1500 RPM at 65 MPH. This is far to low isn't it?? I know corvettes run at 1300 RPM on the hiway(same tranny), but this can't be done with my carburated engine can it? people say I need my engine at a minimium of 2000 RPM.
I really would like an overdrive but I don't know of any other popular affordable Trannys that will hold up to 500lbs of torque..? muncies are great, but they lack an over drive, I don't want to drive down the hiway doing 3300 RPM.
I wanted a Tremec TKO-600 but they are too much (would have been perfect).
Have any ideas!??
smoknbarrels is offline   Reply With Quote
Old 02-06-2007, 11:12 PM   #2
cooters
Re: What is the best cruising RPM ?? I need a good rear ratio and tranny!
i dont know what you have for a motor combo, a 454 with an rv style cam would be awesome at 2000rpm.
cooters is offline   Reply With Quote
Old 02-07-2007, 12:41 AM   #3
smoknbarrels
Registered Mail
My 454 has ported heads, intake, headers, with a few other goodies, but the big thing affecting my RPM would be my cam , which is 292 adv. duration and 550 valve lift. so it is much larger then an RV cam. its power band is about 2500-6500 RPM.
I don't nessisarily think that I need to be cruising in that range do I?
would it run good under 2000 RPM on the hiway? perhaps someone has tried this before...
Old 02-07-2007, 01:00 AM   #4
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
here are some #'s for ya. Hope they will help. I'm not real sure about the bigblock stuff cam seems a little big just the #'s
Ratio = (rpm x tire diameter) divided by (mph x 336)
RPM = (mph x gear ratio x 336) divided by (tire diameter)
MPH = (rpm x tire diameter) divided by (gear ratio x 336)
Tire Diameter = (mph x gear ratio x 336) divided by (rpm)
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 02-07-2007, 01:41 AM   #5
smoknbarrels
Registered Mail
yea, i have been using some good online calculators, but I just don't know what would be a good RPM to run my big block with on the hiway..?
Does anyone know of a good strong manual tranny that has good ratios?
I can get my hands on a cheap Borg Warner super T-10, if I have to go to a 4 speed (is it as strong as a muncie?) but then I also go to a 3.08 ratio rear end.
Old 02-07-2007, 09:49 AM   #6
cooters
you should be in the power range while cruising. Depending what you are doing, a new process 4500 is ok, or a T5
Old 02-07-2007, 10:53 AM   #7
71Chevy4-speed
Speed Limit = Floorboard
71Chevy4-speed's Avatar
http://www.richmondgear.com/01sixspeed.html
5th is 1:1
6th is overdrive.
1971 C20 350, 4-speed - Sold.
1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project.
"Build for torque, horsepower will follow"
71Chevy4-speed is offline   Reply With Quote
Old 02-07-2007, 01:30 PM   #8
smoknbarrels
Registered Mail
that looks good, you can even pick all your ratios.. also looks expensive.. i think i looked at these richmond 6 gears before.. but they were in the $3000 range.. which is unfortunately a little out of my range. since they are not common i would have to buy it new..
I have been looking at the T-56 that LS-1's use.. its a 6 speed.. all gears are good but 6th is too low of ratio, so I was thinking of just only driving with 5 gears. since those trannys are popular and cheap.
perhaps call 6th gear a "police interceptor passing gear" since I would be doing 230 MPH @ 5000 RPM with my set up. LOL..! sounds like a waste thou.
Old 02-07-2007, 03:52 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
a T 5 can't hold up to a strong 305, there's a reason GM never bolted them to a 350... ever.
Are you racing your big block, or just want a kick ass strong motor?
You should have enough torque to not need real deep gears. A normal old 4 speed stick, or a Th400 if you are sick of shifting, would be idea with a 3.07 gear. You'll cruise at 2500 or so.
Old 02-07-2007, 04:12 PM   #10
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Hey longhorn - are you on 315 doing 90mph? That could be to slow
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 02-07-2007, 05:07 PM   #11
Longhorn Man
west side on I 270 north bound, had it at 100 for a mile or so, had to lift for the exit to I 70 west.
I can't remember where the first photo was taken, that's when the old GMC rolled 500,000 miles.
Old 02-07-2007, 05:56 PM   #12
67ChevyRedneck
67ChevyRedneck's Avatar
If you really want OD, why not a tremec 5 speed and a 3.73 rear end? That should give you what you want, right?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-07-2007, 06:12 PM   #13
smoknbarrels
Registered Mail
I will be running about 470 HP in my 454 (Flywheel HP) so i have been trying to find a decent manual tranny that will hold. I also want to determine what RPM is good to cruise at, (being I have lots of cam).
sounds crazy but i am trying to get the best of both worlds, I want it to be a tough street machine, but also have an over drive gear so it will see pleanty of use on the hiway.
Old 02-07-2007, 07:05 PM   #14
Longhorn Man
If I'm not mistaken, the tremec 5 speed is not an overdrive.
2000 - 2500 RPM is what I would say you should shoot for.
Any idea on what kinda torque numbers this engine will pull? If it has a bunch of torque down low, then a low gear would be wasted. The caddy motors make so much low end power that you can run real low gears, like a high 2.something, and it'll still pull like crazy from the lights, yes loaf along at 2000 RPM in a one to one final gear. With a tall gear, there is no need for an overdrive, and you indicated cost being an issue... there are no low cost overdrives that'll handle your engine... not for a long peroid of time anyways.
