Old 02-06-2007, 11:54 PM   #1
Litemup
Steel Horse Cowboy
Litemup's Avatar
6 Lugs, am I crazy to keep it?
I have a 68 gmc with 6 lugs, I'm thinking I want to keep it that way. From most of what I've heard I'm insane, I hear that parts are more expensive and harder to find. I really only care about the rear end, I could care less about wheels I'm not a flashy wheel guy. But I want to do a lposi rear end or some type of LSD evetually, I'm knew to the older car world and I'm not sure how it works, can I get a all the posi stuff and find 6 lug axles that would spline in, is that the really expensive part, or do I need like a special carrier? I'm not sure if the splines are different on 6 lug axles..
Input, ideas?
Litemup is offline   Reply With Quote
Old 02-07-2007, 12:00 AM   #2
Rascal_one2001
Rascal_one2001's Avatar
Re: 6 Lugs, am I crazy to keep it?
all that matter with putting in a posi is the correct spline count 5 and 6 are same and that you get a posi unit for a 12 bolt rear end aslong as your hasn't ben swaped for a 10 bolt then you would have to get a 10 bolt posi carrier with the correct spline count. I would recomend switching to 5 lug since you can convert to disk fronts and wheels are much easyer to find.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 02-07-2007, 12:19 AM   #3
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I still have 6 bolts and find it perfectly fine. The 6 bolt kit for front disks was the same price as 5 bolt. Besides, if I ever want to switch the rear to 5 bolt I can just do it and swap front rotors (which could be worn out by then), cheaper than doing front and rear at same time. (but more $ in the long run, but not much).
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-07-2007, 12:33 AM   #4
409biscayne
409biscayne's Avatar
I have one truck with 5 and one truck with 6 , no big deal , except there's more choice for 5 lug rims , really just about a wash .
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 02-07-2007, 12:50 AM   #5
roj2323
keeping the 6 lug is cheaper since you only have to purchase custom rotors if you decide to go with front disc. cost is around $100 for a set. if you convert it's more expencive but parts are easier to obtain. the front 5 lug rotors and rear 5 lug drums are avalable at any parts store and are around $30 each. for a total 5lug conversion it costs around $500 if you count converting to front disc seperatly. BTW in my experince it is alot cheaper to purchase everything you need to convert the front to disc at the parts store than buy a kit. granted you could swap the front crossmember but why bolt on old parts when new ones are cheap. all it takes is a little time and common sence. it took me 4 hrs with all new parts to convert my 69 to front disc. i did save a little money by using stock spindles but that's up to you. it's really a great time to install drop spindles and springs if you go that route.
ondrew
ondrew
roj2323 is offline   Reply With Quote
Old 02-07-2007, 01:22 AM   #6
Litemup
Steel Horse Cowboy
Litemup's Avatar
Thanks guys, on my purchase list is a set of drop spindles, was really just deciding on keeping the 6 lugs or not, I think I'll keep them around for now, 5 lug does have the advantage for wheel choice but i'm more a stock steely guy anyway.
