Old 02-07-2007, 08:30 AM   #1
gregbr
Senoir Member
gregbr's Avatar
Rear axle u-bolt torque??
The manual is a bit confusing on how much to torque the rear axle u-bolts on a 2wd, 12 bolt, with the inverted square bolts (nuts under the axle). I have new 1/2 u-bolts. Thanks in advance. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 02-07-2007, 08:43 AM   #2
byrd
Union Electrician
byrd's Avatar
Re: Rear axle u-bolt torque??
225 ft lbs it is not fun getting them to the setting. although the manual says 195-225, I went with the higher number.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 02-07-2007, 10:39 AM   #3
68haywagon
I'm watching you!
I didn't use a torque wrench on mine because of the wierd position I was in, but three long grunts pulling the bar with all my weight should have brought it close
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 02-07-2007, 11:08 AM   #4
jimmydean
jimmydean's Avatar
Wrench until it hurts, then 1/4 more and you should be about right.
It too a 36" breaker bar and both legs to get mine off. After that, getting them on was easy.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-07-2007, 12:31 PM   #5
jamesi20
jamesi20's Avatar
tighten them until they squeak...then half a turn
jamesi20 is offline   Reply With Quote
Old 02-07-2007, 01:00 PM   #6
gregbr
Senoir Member
gregbr's Avatar
Dang, that's sounds like alot for a 1/2" bolt. I'd hate to see what the 4wd u-bolts torque to, since they're a little bigger. Thanks, Greg
Old 02-07-2007, 01:06 PM   #7
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
I torqued mine with a 30 inch bar, and all the strength I could muster. Not looking forward to ever taking them back off.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 02-07-2007, 02:49 PM   #8
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
if you going to take them off i would just cut them off and put new u bolts on
no grunt work here
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 02-07-2007, 10:32 PM   #9
slt0066
I dont have a manual and im no expert but 225 ft lbs seems crazy.
i can tell you that every nascar team runs the same rear suspension as our trucks and with 3/4 inch u bolts torqued to 100 ft lbs.
Im suprised they dont snap at 225 ???
slt0066 is offline   Reply With Quote
