Old 02-07-2007, 10:26 AM   #1
bigo181979
Junior Member
bigo181979's Avatar
6 lug Disk Break swap, cheapist way????
What is the least expensive way to put six lug disks, on a 68.
I know their are some spindle swaps that people are doing from other trucks but everything I have seen is a five lug.
Is their a way to do this inexspensively or do I have to go with a kit like ECE or CPP offers.
bigo181979 is offline   Reply With Quote
Old 02-07-2007, 10:48 AM   #2
Aarons72s
Re: 6 lug Disk Break swap, cheapist way????
There was a kit that used a slip on rotor and caliper brackets that used the existing brake drum spindales and hubs. I will see if I can find the link. They did it in a magazine a few years back lets see if I can find the magazine this time.
http://67-72chevytrucks.com/vboard/s...ighlight=brake
Aarons72s is offline   Reply With Quote
Old 02-07-2007, 10:51 AM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
I bought a complete suspension off a 71 GMC for $120 at a junkyard, swapped everything, then bought the expensive ECE rotors.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-07-2007, 03:17 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
http://www.crussenclassics.com/ heres a kit thats the easy way to convert to disc brakes
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 02-07-2007, 03:55 PM   #5
Primer69er
Just gettin started!
Primer69er's Avatar
not sure here, but would anything from the 97 or so z71 fit, i know its 4x4, i dont know anything about it, but just figured maybe something would work.
Primer69er is offline   Reply With Quote
Old 02-07-2007, 03:56 PM   #6
jimmydean
jimmydean's Avatar
I got a 2.5" drop spindle kit from GMC Pauls for $460. Those guys want $670? Ouch!
That to me was the most straight forward way to do it. I kept all my '69 steering related stuff and all the ball joints and everything, just got the drop spindle and the better bearings.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-07-2007, 07:18 PM   #7
67 cst swb
67 cst swb's Avatar
I put spindles from a 88-92 Chevrolet C2500 2wd (Lt. 3/4 ton uses 6 lug disc) on my truck... I did need to research the tie rod ends, and ball joints...
I used the 88-92 Spindle, caliper, rotor, ball joints (upper & lower). I used a mid-70's 3/4 ton lower control arm... (ball joint hole is larger and fits the 88-92 ball joint) Tie rod end I don't remember but it did all work... I did happen to have alot of this stuff already, so it made it cheaper for me.
I got the idea from a guy from Dallas. He may have more info... I'll try and find his name and repost it or do a search for the original thread. all his info was correct and right on...
try this... look down with-in the thread for FirstGen's posts
http://67-72chevytrucks.com/vboard/s...d.php?t=177230
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 02-08-2007, 02:47 AM   #8
bigo181979
Junior Member
bigo181979's Avatar
Thats more along the lines of what i was looking for.
Old 02-08-2007, 08:17 AM   #9
arkracing
Weekend Warrior
Swap the whole front end from a '73-'87 (H.D. Front Rotors 1.25" Thick) Truck under it - the whole crossmemeber will bolt in - or you can put all the control arms, spindles, steering links etc on the '68 crossmember. The rubber brake hoses will need to be from a '71-'72 to work correctly.
Then buy the 6 lug rotors and put them on.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
