Powdercoating Ramhorn Manifolds
ANYBODY GOT ANY PICS OF POWDERCOATED RAMHORN MANIFOLDS? I LEARNED HOW TO DO IT YESTERDAY AT PTS AND I WANT TO POWDER COAT A SET I HAVE THAT WILL SOON GO ON WHEN I REDO MY EXHAUST. WILL IT HOLD UP?? WHAT COLOR WOOD BE GOOD? I WILL POST PICKS WHEN I GET DONE.
1972 C-10 SWB 350CI TURBO 350 TRANNY, TILT, POWER WINDOW & BRAKES, TANK UNDER THE BED W/MARKER LIGHT FILLER. 3.08 GEARS, CLASSIC AIR ![]() ![]() 2000 chevy blazer 1990 nissan pick-up 1984 mazda pick-up (son's project truck) |
Re: Powdercoating Ramhorn Manifolds
regular powder will burn off you'd need the hitemp stuff/ i prefer ceramic coat
I got a bunch of high temp powder from Pendry Powdercoating, but I don't know that they carry it anymore. You might want to email George and see if he still has it, I didn't see it on the site. Check ebay also.
The stuff I got only comes in flat black, cures at 400 and is good to 1700 degrees. It was $15 a pound and you can do about 5 sets with a pound. Worked very well on both dirt bike and truck pipes.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
You will need to use the hi temp ceramic powder for manifolds or headers. But you can get this powder in different colors if you want an original or custom look.
http://www.eastwoodco.com/jump.jsp?i...44&iSubCat=850
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
#5 | |
![]() Join Date: Mar 2004
So you know: caps are equivalent to yelling on the Internet please mind your caps. Not using caps also lets you use spell check. Flat black would work but make sure it's a ceramic powder coat as the normal stuff will likely crack. OnDrew Last edited by roj2323; 02-07-2007 at 05:17 PM. |
#6 | |
'67 C10 Short Stepside 5.0TPI/700R4 |
It's just good grammar, to start a sentance with a capital letter.
![]() Back on topic... Black or silver would be my first choice, but color matching the engine, and accessories could be cool... I'll take my manifolds / headers in Blaze Orange ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
In Memoriam...
I remember seeing some polished and "coated" 'vette ram-horns on N2TRUX's RJ350. I don't know what coating he used, but you may want to PM him and ask.
They looked really boss.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
I bought the 1200 degree paint @ auto-zone yesterday. While is was @ work @ PTS (engine shop) I put my manifolds in the shop blast machine and ran them for about 30 min. took them out,blew em off then painted them. I then got the oven up to about 200 degrees and let it get to about 400 degrees then shut the oven off and let them cool. When they cooled to around 125 I fired it back up and cooked them for about 30 min. @ 600. I hope they turned out well
I will take pictures this evening and post tommorow.
#11 | |
Sierra Grande Club
Are you going to use the locking retainer on you manifolds? I’m going to paint mine just in case I need them. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
locking retainer????? what is that? i will use new bolts
#13 |
Next project: 1970 K10
Last time I used AutoZone hi-temp paint on ram-horns, it burned off in the first 5 minutes! Grind smooth, sandblast, ceramic coat.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 02-14-2007 at 10:34 PM. |
#14 |
Bob Last edited by cheyenne10; 02-15-2007 at 12:41 AM. |
