Old 02-07-2007, 04:34 PM   #1
uno67
uno67's Avatar
are theses the headers to use on baged trucks
need help picking the exact header for my truck with airbags. right now i have the hooker comps fit great but i think its going to cause problems with the way i run my exhaust. searched on the site and alot of people using the headers for camaros, but i couldn't find that many pictures or part numbers. can you guys tell me if these will do the trick http://store.summitracing.com/partde...5&autoview=sku
uno67 is offline   Reply With Quote
Old 02-07-2007, 05:30 PM   #2
jimmydean
jimmydean's Avatar
Re: are theses the headers to use on baged trucks
I plan to run the 3/4 length headers from Skip White on ebay. They are for 88-95 trucks, but they fit with a little trimming on the driver side and you have to plug the O2 bung. They are only $160 and they are ceramic coated, not a bad deal.
I was told a Camaro headers don't fit because they hit the motor mount on the driver side.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-07-2007, 05:36 PM   #3
72chevy327
I was told a Camaro headers don't fit because they hit the motor mount on the driver side.[/QUOTE]
what headers will fit.
72chevy327 is offline   Reply With Quote
Old 02-08-2007, 01:31 PM   #4
svgould
Active Member
svgould's Avatar
I'm running the camaro headers on 71 2wd. No problems with hitting motor mounts, but did have to trim about 1/8 -1/4 of an inch of upper frame rail on passenger side......no big deal!! For pics and part number go here
http://67-72chevytrucks.com/vboard/s...d.php?t=166291
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 02-08-2007, 10:14 PM   #5
dingo_dan_22
dingo_dan_22's Avatar
I first tried some shorty headers out of a firebird and the drivers side hit the a-arm.
71' Chevrolet -> 350c.i. w/ 600 Edelbrock Carb, Headers, P/S, 3/5 Drop
dingo_dan_22 is offline   Reply With Quote
Old 02-08-2007, 10:24 PM   #6
Shane
Shane's Avatar
I have 3/4 length headers for a Chevelle/Malibu ... they don't rub anywhere.
Shane is offline   Reply With Quote
Old 02-08-2007, 11:19 PM   #7
brak
brak's Avatar
maybe i missed something, but why not use the shorties designed for our trucks, as they are readily available...
I know both hooker and heddman have them
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 02-09-2007, 12:23 AM   #8
pissonNOS
senior member
pissonNOS's Avatar
how low are you going to be to need these headers? im bagging my truck with stock spindles and no nothc think ill be ok?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 02-09-2007, 02:48 AM   #9
uno67
uno67's Avatar
the hooker comps i have now hang down about three inches and since i'm putting in a new tranny crossmember and a new drop center crossmember i want to run the exhaust between the frame rails. i have it bagged with the drop spindles and the headers aren't that bad the only time it hits is when its aired down all the way. but i can take better advantage of the new crossmembers with new shorty headers or 3/4 headers just need to figure out which ones.
