tach
What type of after market tach looks good and actuall fits in our empty tach space?
Keepin an eye out
Re: tach
70's Camaro.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Keepin an eye out
Re: tach
Opps I see you said aftermarket, but I woud do a Camaro tach.
Re: tach
If you can wait a week...I will show you as I'm re-doing mine right now.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
Re: tach
I will be waiting...
Re: tach
I have a SunTune in mine.
Re: tach
Right before the great "stock tachs suck for accuracy" thread on this forum I bought a used tach dash off the parts list. Before I got it installed I decided to go with a new aftermarket tach.
I had the factory setup for a template. I had a complete gauge setup minus the speedo that I bought at a swap for $1. A $1 setup is a perfect candidate to go under the knife. I had a hole saw that was near the same size as the original tach hole. I used the factory tach tin to help me figure out where to drill. NOTE that the tach hole is NOT in the middle of the hole in the bezel. It is offset down to account for the fact that when installed you will be looking down at an angle. I had to fab a bracket to hold the back of the tach. Since this was metal I used that paint-on rubberized coating on the edges so my printed circuit doesn't get rubbed through. While I was at it I installed a "Quartz" clock out of a mid-80s Sub that I found in the yard. That thing is VERY accurate. Somebody on this list suggested a heated nail to make the hole in the factory lens. This worked good. I would guess that drilling a hole would chip or crack the 35 year old plastic. Finally I used plastic polish to remove factory markings on the lens in front of the previously empty gauge spots. Note that in the 2nd picture I used a 4-wire trailer plug on the tach connections. That way I can remove the dash bezel if I need to.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Re: tach
here is a dash with camaro tach
Re: tach
Nice, dmec. What did your oil, bat and temp gauges come out of? Looks to give a lot more detailed info.
1969 C/10 swb, 350, powerglide (daily driver) 2005 CRV (wife's ride) |
Re: tach
gauges are from 80's chevy pickup. also found a vac gauge from same vintage 1 or 2 ton truck.
Re: tach
what year is that camaro tach from?
Travis
travis_moffatt@hotmail.com ![]() 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
Re: tach
70 to 80
#13 |
Re: tach
nice job
way to go on the small gauges too. way better
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#14 |
Re: tach
Here is what I just did, bought the dash assembly and added the tach... because, well, I can't just leave well enough alone.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 02-08-2007 at 10:43 PM. |
#15 |
![]() Join Date: Sep 2003
Re: tach
I bought an AutoMeter (10,000 rpm) tach on e-Bay and plan on running it on the 4 cyl mode to make it a 5k tach. I'm going to get a tach gauge bezel for the numbers.
I sanded and painted the face and added a shortened speedo needle. It's not done yet, but it's coming together nice:
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
#16 |
Re: tach
i would like to see it after you install the printed circuit
#17 |
Re: tach
who makes that white faced tach that is nice
Travis
#18 |
Re: tach
It's a new gauge line that Checker/Kragen or whatever they are called now has. I was buying some hoses and they had the display behind the counter, I went home and grabbed my busted up cluster and went back to check the fit. It fit right in there so I bought it. Didn't realize that the white part didn't exactly match, but I can live with it for the price I paid all tolled.
