Old 02-07-2007, 09:30 PM   #1
72chevy327
383 stroker
Im building one with a 400 crank, and was wondering if i could use 5.7 rods and 383 pistons, or do i hafto change my rods to 6.0 and use 350 pistons. by my thinking the 400 crank has the same stroke as a stroker crank so it wouldent matter witch way you did it. but iv never built a 383 so. thanks.
72chevy327 is offline   Reply With Quote
Old 02-07-2007, 10:44 PM   #2
b&a72
Active Member
b&a72's Avatar
Re: 383 stroker
No that set up is fine. I use the same one 400 crank, 5.7 rods, and flat top 383 pistons and she runs like a champ.
b&a72 is offline   Reply With Quote
Old 02-07-2007, 10:51 PM   #3
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: 383 stroker
as long as your 383 pistons were ordered for 3.75 stroke 5.7 rods you got it.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 02-07-2007, 10:54 PM   #4
72chevy327
Re: 383 stroker
Thanks alot thats a BIG help.
Old 02-07-2007, 11:14 PM   #5
hp1967c10
hp1967c10's Avatar
Re: 383 stroker
I have a 388 (.060 over rather than .030) and I experienced an issue with the pistone skirts hitting the throws on the crank. This is easily corrected by removing just enough of the skirt to clear. Needless to say, balance rotating assembly after clearances are achieved.
Happy Truckin
HP
hp1967c10 is offline   Reply With Quote
Old 02-09-2007, 09:10 PM   #6
72chevy327
Re: 383 stroker
whats the hightest CR i can go and still use reg gas.its 9.6 or 10.8 what should i go with.
Old 02-09-2007, 09:55 PM   #7
Stroker
Re: 383 stroker
72chevy, Are you planning to use a production 400 crank? If so the mains will need to be turned. You may find the machine work cost to prep the crank are as much if not more than the cost to purchase a stroker crank.
I noticed the 327 in your user name, are you planning to use a 327 block for the stroker motor? If so it's important to know if you're starting with a large or small journel block.
The piston rod combination has already been answered but you can have clearance issue between the rod bolts and camshaft. Most machine shops know what needs to be done and can clearance the rods when they resize and static balance the rods.
You might look into some of the stroker kits. When I built my motor my thinking was I would rework and reuse the stock rods to save a little money since I felt they would support the power levels I was aiming for. When all the machine work was completed (magged, resized, new rod bolts, balanced and clearanced) I could have had much better rods in the engine for about another $75-$100. And probably saved some money if I would have bought a kit including crank, rods, pistons, bearings and rings.
Compression Ratio and fuel tolerance. There are a lot of things that factor into this question. Two major items combustion chamber shape and material, and camshaft specs. Gearing, weight, qwench, altitude, air temps and water temps can also be important in determining the max compression with a given fuel. Do you know what heads your going to use? Cam? Do you use your truck to tow?
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 02-09-2007, 10:01 PM   #8
RetroSBK
Re: 383 stroker
I run 9.8 CR with Alum heads and do so on 87 octane all day long... 383 with Scat forged crank and rods, no problems
Well except that the new engine promptly smoked the stock 700R4... Hello , TCI, Super Street Fighter please...
Will
1970 C10, shortened long bed, Alum Headed full roller 383 (with Victor, 750DP, stainless rockers, behive springs, CNC ported heads) TCI SSF 700R4, 4.10 Posi, Bagged on C-Notch and 2.5 spindles. Air Cond, black out tint, satin black paint, custom interior, rolling low and not so slow...
RetroSBK is offline   Reply With Quote
Old 02-09-2007, 10:07 PM   #9
72chevy327
Re: 383 stroker
thanks for all the info Stroker. Im starting with a 350 4bolt main and the crank i have has been turned down to std mains and .010 throws. my 327 is no more it seems you cant trust the machine shop to put heads together for a 450hp roller 327. i got a full refund and all the not f'ed parts back.
