gas tank swap
need help and info on what is the best and cheapest way to swap out the gas tank on my 86 shortbed stepside? would like to put the tank in the rear between the frame, just not sure of what will work. thanks
Professional Grade
Re: gas tank swap
Best and cheapest is a stock K5 32 gallon tank!
Here is how I did the swap on my truck, except I used a 43 gallon Suburban tank on my longbox fleetside: http://www.captkaoscustoms.com/blazertank.html You'll notice that if you keep your tank full, your truck will ride nicer, and even stop better with a bit more weight behind the rear wheels. I know my stepside always locked the rears up way before the fronts, and almost got me into trouble a few times... Toughest part of the whole swap is routing fuel lines, and figuring out a filler neck. Filler neck should be reasonably easy with a stepside though, just shave the marker lights, and swap the fenders around, should put the fuel fill at the back of the passenger side of the truck, right where you want it ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 02-07-2007 at 10:04 PM. |
Re: gas tank swap
so the tanks are off of a blazer? and of the same year as my truck? thanks for all your help
Professional Grade
Re: gas tank swap
Any K5 tank from 73-86 will work fine for your swap. In 87 the K5s started getting fuel injection, and have pumps in the tank.
Some Suburbans got the smaller K5 tanks, and likewise, some K5s got the big Suburban tanks. You'll want the smaller tank for a shortbox. The big Suburban tank just barely clears my diff at full droop in my longbox
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Re: gas tank swap
I know I am about to sound dumb here, but when you say the smaller tank, would that be the 25 or the 31 gallon tank, cause you also mentioned the 43 gallon tank----thanks
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: gas tank swap
That's my write-up, so yes, it is the 25gal tank for the SWB.
I wasn't sure if you were asking or not, but the pickup tank and the Blazer tank are not in any way simular.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Garage Queen Material
Re: gas tank swap
OR you could do the fuel cell like i plan on doing
http://73-87.com/7387garage/chassis_...ellinstall.htm |
Re: gas tank swap
If you have a LWB, do you still have to move the rear frame support?
I am thinking about this for my 86 K10 Thanks Duro |
Re: gas tank swap
sorry to bring this back up, but i am looking to do this swap to my truck. The only tank offered is a 31 gallon for the k5 and jimmy? I am needing an 87 an dup tank for the FI. Will the 31 gallon tank work on my shortbox?
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq Last edited by BaddBusa2005; 04-11-2007 at 04:52 PM. |
Professional Grade
Re: gas tank swap
The 31 gallon is the smaller tank, and will fit nicely between your frame rails
![]() The big one is 43 gallons, which I put in my truck, and that is very tight squeeze on a longbox...
Re: gas tank swap
i got to do something too.i just stopped using the passenger side after i ran it dry for leaks.i don't drive mine too much or to far.so,16 gallons gets me around.but i remember when gm just about lost the farm over these tanks.so when i do something it's going to be like russell,and chris's write up did between the rails.25 gallons would do me fine.
" Never look up a dead dogs butt." ![]() |
Chris
Re: gas tank swap
I would like to do the same thing, but don't you have to remove a crossmember or something and maybe cut the bed sill?
I don't want to cut up the frame or move a crossmember because I have no acess to a welder. Any help? Do I need to move a crossmember or anything? Mines an 84 swb fleetside?
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
#13 | ||||
Re: gas tank swap
There is no 43g tank, all capacities are approximate also. Quote:
#14 | |
Re: gas tank swap
#15 | |
Re: gas tank swap
Chris, If you get a chance will you price me a fuel injection 25 gallon tank, and straps? Thanks, Ryan
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq Last edited by BaddBusa2005; 04-13-2007 at 01:10 PM. |
#16 |
Professional Grade
Re: gas tank swap
Ah, cool, had no idea there was a smaller tank than 31 gallons
![]() I'm thinking I might ditch the burb tank though, its a real hassle to try and install a fuel door in the rear for the tank, and no nice way to get around it as far as I can tell ![]()
#17 |
Re: gas tank swap
i am going to put a billet door recessed in the bed side
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq Last edited by BaddBusa2005; 04-14-2007 at 10:59 AM. |
#18 |
Professional Grade
Re: gas tank swap
The biggest problem with that is you have to cut out a square in the inner box wall, and some out of the floor as well to get the filler neck high enough to make sure the fuel pours down and into the tank rather than straight back out the filler neck, lol :d
#19 | |
Re: gas tank swap
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
