The Original HotRod KnifeMaker
![]() Join Date: Jan 2007
WTB 67-68 Driveline Seattle/Portland area
for a turbo 400 shortshaft, SWB, 2wd with leaf-spring rear end
Thanks, Dave |
![]() Join Date: Nov 2002
Re: WTB 67-68 Driveline Seattle/Portland area
what length? are you needing the 400 yoke also?
I haven't one that fits to measure- my original one is too short. Converted from 350/350 long-shaft to 396 and a 400 trans with short shaft-.
I do want the front yoke, also. Thanks, Dave |
go lay under the truck and measure from center of cups on the rearend to the tail of the tranny and then subtract 2 or 3 inches, that'll be the center of the tranny yoke. I have 2 or 3 laying around here, but to be honest, you can get the measurement and go to the junkyard and find the right length. The one in my 67 shorty is out of a dodge van. Let me know, one of these might be the right length.
ttt
Dave 69 GMC SWB 2WD 454 Turbo 400 |
Got the new length measured- 60.25 end to end. If you have one would there be a way to get it near Olympia?
Thanks,
67 shorty
do you have the top mount or bottom mount carrier bearing? If you want a direct bolt up this matters, right?
67 SWB with enough parts to build two ![]() |
