I found a 427 in a Caddy at the local Pick 'n Pull, do you guys think it would be worth the $140 or not. Also what do you think it has for a trans. I am building a 388 stroker but I thought that this would be a good motor to throw in the truck to get her on the road untill the 388 is done. So I guess the real question is how much work to make this engine fit?
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Re: Caddy 427
I would jump on that real fast for $140.00 bills. It probably has a 400 trans in it.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
its all about the +6 inches
Re: Caddy 427
you talkin a 472... or a 429?
Re: Caddy 427
7.0 liter
Re: Caddy 427
if not mistaken, that could be a 425 or a 429.
The 429 is a vary outdated, overweight, underpowered pig. The 425, 472, 500... they are monsters, and WELL worth your time. |
Re: Caddy 427
How can I tell while the engine is in the car?
Designated A-hole!
Re: Caddy 427
What car is it in?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Re: Caddy 427
I do not know to tell you the truth, I'll have to check tomarrow
blood type; Retumbo
Re: Caddy 427
take some pics and some of us caddy freaks can tell from them.
Re: Caddy 427
I will try to take some this weekend
Re: Caddy 427
does a caddy have a distribitor in front like a ford?
1972 C-10 SWB 350CI TURBO 350 TRANNY, TILT, POWER WINDOW & BRAKES, TANK UNDER THE BED W/MARKER LIGHT FILLER. 3.08 GEARS, CLASSIC AIR ![]() ![]() 2000 chevy blazer 1990 nissan pick-up 1984 mazda pick-up (son's project truck) |
blood type; Retumbo
Re: Caddy 427
I know the 472/500/425/368 all had the dizzy up front. I think the 429 may have also.
check out www.500cid.com |
#13 |
Re: Caddy 427
Are you asking how much work to put a big block Caddy engine in your C-10 pickup truck for a short period and then you'll pull it and go to a SBC you're building? If yours has a small block now, it'd be quite a bit of work (exhaust, motor mounts, (tranny crossmember?), wiring, alternator and maybe power steering bracketry (if you have it), and perhaps a dozen smaller issues.
If that $140 motor turns out to be a Chevy 427 engine, then let us know and we'll talk you out of the SBC buildup all together.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
#14 |
Re: Caddy 427
a cad engine is nothing to install, but with the added cost of a tranny ( I don't recomend adapters) I wouldn't recomed the cad as a temp motor.
Besides, once you feel that torque, it'd take a hell of a small block to ever make you smile again. |
#15 |
Re: Caddy 427
Well guys I went back to Pick N Pull today that engine is in a 79 Fleetwood> I did some more looking around and found a 67 C10 longbed 2wd. So I ended up leaving with the factory bucket seats and the power brake booster set up, only cost me $75 for every thing.
#16 | |
![]() Join Date: Dec 2006
Re: Caddy 427
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#17 | |
Fabricate till you "puke"
Re: Caddy 427
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 02-11-2007 at 08:35 PM. Reason: the W was upside down(lol) |
#18 |
![]() Join Date: Jul 2005
Re: Caddy 427
http://www.geocities.com/caddyoneton/
If you do plan a caddy swap read this. Saved this from longhornman. I think.
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
#19 |
Re: Caddy 427
#20 |
Re: Caddy 427
larry may, i was just about to start looking for that... yes,. that is mine.
