Old 08-27-2002, 04:14 PM   #1
1967LWBstepside
'Heavy Metal' Redefined.
1967LWBstepside's Avatar
Metering Rod Spring Kit for Carter AFB
I have a Carter AFB 500 cfm carb on my 250. It's running a bit too rich. Is there anyway to change the jets on a Carter or do I need to get a metering rod spring kit and use trial and error until I get a good match for this engine?
The metering rod spring kit is found at Summit Racing http://store.summitracing.com/defaul...rchType%3DBoth but I've never done this before. Is there anything else I should do to lean the carb down?
Thanks.
1967 C10 LWB stepside, 250 engine, GM HEI, aftermarket A/C., Clifford Performance intake, Stovebolt split headers, Carter AFB 500, X-pipe & Dynomax Super Turbos, 1 piece custom driveshaft, cyprus bed wood & stainless bed strips.
Starkville, Mississippi | My Truck Page
1967LWBstepside is offline   Reply With Quote
Old 08-27-2002, 04:25 PM   #2
tom hand
CCRider
tom hand's Avatar
I wouldn't think you need to change the springs unless you are running a big cam that reduces the vacuum. If it is just running rich you might can fix that just by changing the metering rods without taking the top off the carb. I see you are in Starkville, went thru there last weekend for the bike rally in Sturgis.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 08-27-2002, 05:31 PM   #3
jku72
Carter AFB's are such a sinch to change metering rods, if you have 5 minutes, you can lean that bad boy down. So simple it is scary.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 08-27-2002, 05:44 PM   #4
1967LWBstepside
Do I have to take the top off the carb to get to the metering rods? I'm sure this is a stupid questions. Also, any size recommendations?
Thanks.
Old 08-28-2002, 07:38 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Post
On the top of the carb there are 2 small plates held with 1 tiny screw for each. Remove the screw and plate and pull the metering rod out.
For fine tuning, a different spring will work. For more fo a change, a different rod can be used. To make a major change, the jets may need to be swapped.
I bought one of the strip kits from Summit and you'll be lucky if you use 2 pieces out of the whole thing but... This kit contains an assortment of metering rods and jets only. No springs.
In most cases, the springs or rods will do the trick.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-28-2002, 09:29 AM   #6
tom hand
CCRider
tom hand's Avatar
Tech Tip: DO NOT remove the screws when changing metering rods. They are way too easy to drop into the carb. Loosen them just enought to spin the little plates out of the way.
Olive Branch MS
Old 08-28-2002, 08:42 PM   #7
1967LWBstepside
Thanks, Men, for all the good advice. Once I find the parts I should have her leaned down a bit. Can hardly wait . . .
Mike
