Old 04-25-2002, 03:50 PM   #1
brennecke
brennecke's Avatar
Post dicorced to manual conversion?
Has anybody altered thier Q-jet to make it a manual choke? How is it done?
Never tire of doing what is right II Thess. 3:13
Northeast Missouri
71 LWB original 350 3/speed
Soon to be 500
brennecke is offline   Reply With Quote
Old 04-25-2002, 04:36 PM   #2
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
Post
Pretty easy. Get the universal manual choke kit at the local parts store (or a reasonable facsimile), rip off the old bimetallic coil & the rod from the coil to the choke lever (assuming you have such a setup; if you have an electric choke, there should be mounts in the kit to convert from electric to manual). Attach the choke cable mount (mine looks like a squashed Z) to the lowest point on the choke lever when the choke is open. I've found if you tilt the mount towards the front of the engine, the choke tends to stay open with slack in the choke cable.
Before you attach the choke cable to the choke, you have to find a good spot in the cab to mount the knob. Once you have a good spot, route the cable through the firewall, down the left valve cover, around the front of the carb (leave plenty of room for wiring, vacuum & gas lines, and hoses), and attach the cable to the mount. Spray the exposed cable with a bit of WD40, and tweak the cable to yield solid opening & closing of the choke without binding.
67 C20 '78 400sb 0.030" over, 9:1 cr, CC Xtreme 4x4 254H, port-matched '69 882 heads & stock cast iron intake, rebuilt Q-jet, Summit headers (1 5/8" primaries), true dual 2 1/2" glasspacked exhaust, NP435CR trans, 4.57 Eaton rear end.
It's a decent-looking work truck. No top-end, but it's great off the line.
'69 International Loadstar 1700 school bus converted to an RV. Working p/s (only took three years and three owners to replace the belt & a pressure line), low-compression 345 (176 certified net hp @ 3800rpm), single 3" exhaust w/custom cherry bomb muffler, NP435 trans, two-speed Eaton rear end, very warm & rodent-free heaters.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
