Old 02-08-2007, 12:16 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Electric choke for the factory Q-jet?
I’m looking at getting an air gap intake which doesn’t have the divorced choke.
Is there anything I can do short of getting a new carb? Electric choke maybe?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-08-2007, 01:07 PM   #2
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: Electric choke for the factory Q-jet?
TRY here, Not sure if this is what your looking for. if not an electric or manual choke should fix you up. I love the Air gap too.
http://www.carburetion.com/quadrajet.asp
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 02-08-2007, 01:29 PM   #3
Sport/Truck
Sierra Grande Club
That’s cool; I’ll give them a call. I also might need some jetting too.
s/t
Old 02-08-2007, 02:23 PM   #4
Sport/Truck
Sierra Grande Club
That eclectric choke mounts in the same spot the orginal one does. I'm going to need something that mounts to the carb.
Old 02-08-2007, 02:36 PM   #5
68C15
blood type; Retumbo
68C15's Avatar
do you really need a choke in your area?
look at a Qjet from the mid to late 70s and rob the whole assembly from it.
68C15 is offline   Reply With Quote
Old 02-08-2007, 02:56 PM   #6
Sport/Truck
Sierra Grande Club
will this work? Sounds good.
Old 02-08-2007, 03:26 PM   #7
MR MAGOO
MR MAGOO's Avatar
what is the solenoid looking thing-a-ma-jig that the throttle rest on on the right side of a quad? what does the wire hook to? to me it looks like something to idle the motor up with while the a/c is running?
1972 C-10 SWB 350CI TURBO 350 TRANNY, TILT, POWER WINDOW & BRAKES, TANK UNDER THE BED W/MARKER LIGHT FILLER. 3.08 GEARS, CLASSIC AIR :hit2: :hit2: 4 WHEEL DISK BRAKES
2000 chevy blazer
1990 nissan pick-up
1984 mazda pick-up (son's project truck)
MR MAGOO is offline   Reply With Quote
Old 02-08-2007, 04:19 PM   #8
cooters
the early qjets cannot have elecric chokes put on but the mid 70s qjets just need the electric chock installed in the bimetalic housing on the carb
cooters is offline   Reply With Quote
Old 02-08-2007, 04:59 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I don't know jack about quadrajets... however, I DO know that they caddy big blocks had electric chokes on them.
Old 02-08-2007, 09:27 PM   #10
Sport/Truck
Sierra Grande Club
What year should I get a carb from? Is the caddy carb ok to run? In my thinking the newest carb will be the better choice, right? Any years or cars to stay away from when going to you pull it? What size should I be looking for?
Dean
Old 02-08-2007, 10:08 PM   #11
neonlarry
neonlarry's Avatar
This is what your looking for
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-09-2007, 12:02 AM   #12
cooters
tha caddy qjets and olds have the fuel line straight out the front instead of the side. Pick a late 70s q jet, i believe the US qjets went to electronic metering around 81, in Canada ours did not change till 86
Old 02-09-2007, 04:58 AM   #13
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Most Qjets from 1975 on had the choke mounted on the carb. I have a 1976 454 with the divorced choke however. The model 4MC (carb mounted thermostatic choke) and 4ME (carb mounted electric choke) are the models you are looking for. The 4MV is the divorced choke model.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 02-09-2007, 06:38 AM   #14
Well,since these trucks started coming with automatic choke in 69 or 70,Any original carb from that year or newer.Your carb must have been swapped.
Old 02-09-2007, 08:28 AM   #15
68C15
blood type; Retumbo
68C15's Avatar
EXACTLY!!!!!!
look for a 75ish (pre- aneroid) from a light truck or large car. stay with one from a small block, biger engine carbs have a richer fuel curve which is very difficult to make work correctly for your truck.
what i am running is a stock one from a 79 G20 van (engine donor) that I re-calibrated to 72 truck SBC specs. I drilled out the air bleeds and swapped all 4 jets and rods. with mine you can change the lean limit while the engine is running for fine tuning. the older ones you have to remove the carb because the screw is behind a plug on the front of the base plate making access almost impossible.
Old 02-09-2007, 09:14 AM   #16
Sport/Truck
Sierra Grande Club
I thought my choke is considered automatic? It’s just a divorced choke that's non-electric.
s/t
Old 02-09-2007, 09:37 AM   #17
cooters
I have not seen qjets with a choke on the carb until the mid 70s. The early qjets had a few holes for a vent right on top of the carb above the fuel filter housing, you need a carb with the choke housing on the carb.
Old 02-09-2007, 12:03 PM   #18
Sport/Truck
Sierra Grande Club
So what gets hooked the electric choke? 12v on a keyed source or thermal sensor?
Old 02-09-2007, 05:31 PM   #19
neonlarry
neonlarry's Avatar
12V keyed, also take a picture of your carbs linkage with you when you go looking. That carb is off a mid 70's Caddy (795CFM, side fuel inlet) the base plate will need to be changed to one with the right linkage setup or dissembled and put in a throttle shaft with the proper linkage.
