Old 02-08-2007, 03:33 PM   #1
MR MAGOO
MR MAGOO's Avatar
what is it?
what is the solinoid for on the right side of a q-jet used for? what does the wire hook up to? it looks to me like it is to idle the engine up while the a/c is running. the truck i saw it on was in the salvage yard and did not have a/c. pn 500 in the pick
1972 C-10 SWB 350CI TURBO 350 TRANNY, TILT, POWER WINDOW & BRAKES, TANK UNDER THE BED W/MARKER LIGHT FILLER. 3.08 GEARS, CLASSIC AIR :hit2: :hit2: 4 WHEEL DISK BRAKES
2000 chevy blazer
1990 nissan pick-up
1984 mazda pick-up (son's project truck)
MR MAGOO is offline   Reply With Quote
Old 02-08-2007, 04:03 PM   #2
larry may
Re: what is it?
May be fast idle used when first starting the engine ?
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 02-08-2007, 04:16 PM   #3
fosheec
fosheec's Avatar
Re: what is it?
I believe that is the electric choke - I could be wrong though.
Caleb
fosheec is offline   Reply With Quote
Old 02-08-2007, 04:32 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: what is it?
Choke is on the left 336-350
Its some sorta idle sol.Are you sure that carb didnt come off an A/C truck originally.
sneakysnake is offline   Reply With Quote
Old 02-08-2007, 04:45 PM   #5
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
Re: what is it?
it will idle the truck up when you switch the A/C on. Say if you are in a parking lot and switch it on, the solenoid would idle the truck up so the a/c wouldnt kill it. my truck has one, but im pretty sure it doesnt work lol
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 02-08-2007, 04:58 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: what is it?
I'm not certian, I think it is an anti-dieseling solonoid. Turn on the ignition, and it kicks on. The engine will use this as a throttle stop on the idle side of the throttle range. Turn off the ignition switch, and it retracts, shutting the butterflies allt he way. Helps to prevent run on, or dieseling. Early smog control stuff.
