oil puddle on intake
i have a little puddle of oil on the right side of my intake and would like to know what you guys think is causing it or maybe causing it, stock 350 4bbl and stock intake and i dont know whats been done it to, according to the little pencil notes on the door jam it was rebuilt around 85,000 and i was contacted through myspace from i guess one of the previous owners atlest he said he was and he told me it has edlebrock intake and carb yet it has the stock stuff when i get it, ok enough rambleing, ill take pictures in a bit
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Re: oil puddle on intake
Have you checked the valve cover gasket?
![]() ![]() ![]() 67 C10 SWB 350-Turbo 400 tranny-Disc brake "Those who live by the sword get shot by those who don't" |
Pull the intake and reseal it. Use felpro gaskets with a little bit of gasket sealer around the coolant ports. Not around the gas ports. Make sure everything is clean. Run a bead of silicone at the ends of the intake without the rubbers they supply. And you should be good to go.
'67 C20 Lwb 350 4-Speed '01 Chrysler Concorde LXI (wifes ride) '91 Gmc Suburban 3/4 2wd 454 Tbi '51 Jeep Cj3a "Willys" 350 V8 |
Registered Mail
I too have had the mysterious oil puddle on the intake, even only after a rebuild of less then 1000 miles. never knew where it came from. I assumed the valve covers leaked..those old steel valve covers never did ever seal good..
'67 chev 496, lwb to swb, bagged - pro street project |
sufficiently talented fool
![]() Join Date: Jun 2006
Remove the intake manifold bolts closest to the oil and put some teflon thread sealant on them. Re install the bolts and that should stop the leak.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
heres a pic of it for fun
THANKS for the help guys ill try just pulling the bolts and try that first and if that doesnt work i guess ill plan a weekend and pull the intake and give a good cleaning while its off, thanks again
#8 | |
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
I pulled one bolt a night and used permatex thread sealant on it, torque it down and left it set over night. I had 34 bolts that did that, after 4 nights, no more oil puddles.
I did one at a time so I didn't break the seal on the intake and it allowed the thread sealant to set for each bolt.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
Good Info. I will have to do that on mine. I couldn't figure it out either, even though the intake will be coming off.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
