02-08-2007, 06:54 PM | #1 |
New Member
Brackets 454
I have a 1967 C10 pick up with a mid 70's 454 in it. I'm looking to run a serpentine belt drive. I have the chance to get a 1993 454 brackets, and was wondering if they would fit on the mid 70's block. Thanks for any advice.
02-08-2007, 07:28 PM | #2 |
Re: Brackets 454
Im not positive but I think they would work ok, just dont forget to get a later serpentine waterpump too because they run bacwards...
02-08-2007, 08:41 PM | #3 |
Re: Brackets 454
I am in the middle of doing this swap and it is pretty easy. The brackets bolt right up and the crank pulley even worked with the stock balancer. Get a water pump for a early 90's bbc. The problem I am having right now is getting a upper radiator hose that will work. The setup I bought came with a hydraboost pump and I went to the junk yard and got the hydraboost and installed it. I think it looks good in my opinion but some on here think they suck. Whatever floats your boat is what I would use.
