Old 02-08-2007, 09:44 PM   #1
jimmydean
jimmydean's Avatar
Is there a difference in tie rod sleeves?
I was looking at napa online and they list 2 different tie rod adjusting sleeves. One is listed as "manual" and is $16, the other os "power" and is $30.
My '69 was a manual truck and I added a power box. I am replacing my tie rod ends, so should I "upgrade" to the power sleeves? Is there a difference?
My truck drives straight, but the driver front tire has worn on the shoulder in a matter of days. I figured I would replace the upper control shafts and tie rod ends. I replaced the ball joints when I installed the disc brakes.
Is there anything else I should replace as well? The bottom shafts are tight. Thanks.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-09-2007, 09:52 AM   #2
Ram-Man
Ram-Man's Avatar
Re: Is there a difference in tie rod sleeves?
I didn't have a full pic and its too cold to walk to the garage but here are the newer style from POL alot better than the old crimp style.
Ram-Man is offline   Reply With Quote
Old 02-09-2007, 10:25 AM   #3
CMars45000
CMars45000's Avatar
Where did you get those Ram-Man. I have been looking for that style for our trucks. The ones that Hotchkis makes are SWEET but they don't make them in the larger bore to fit our truck, only muscle car stuff that is smaller..
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 02-09-2007, 11:22 AM   #4
jimmydean
jimmydean's Avatar
Yes, where did you get those? I used the disc setup from GMC Pauls, so I am still running my '69 tie rods. Have a link?
Found them here and they are only $50 for the pair!
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-09-2007, 03:01 PM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
will they work as a direct replacement on a stock 69 with drums up front??
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 02-09-2007, 03:17 PM   #6
jimmydean
jimmydean's Avatar
I don't see why not. I am using the same tie rods and the order form say "specify year" so they must make a setup of 63-70.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-09-2007, 09:10 PM   #7
Ram-Man
Ram-Man's Avatar
Sorry for the wait but I got them from performanceonline.com They are really heavy duty I got them in the whole front end kit but here is a link for the seperate.http://performanceonline.com/store/c...cat=787&page=1
Old 02-09-2007, 09:11 PM   #8
Ram-Man
Ram-Man's Avatar
The kit I got changed the tie rod ends to the 73-87 style so I'm not sure about fitting the older ones.
