Sierra Grande Club
Oil pan gasket thick or thin??
I’m looking for a one piece gasket on summit, they list’em as thick or thin front seal. Do you know what I need? How do I tell?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Re: Oil pan gasket thick or thin??
thats news to me, never seen that before. Could be listed that way instead of 1 or 2 piece rear seal?
Not sure personally,
it might help others viewing this thread if you post what you have for an engine. most important, Gen I or Gen II (LT based). If you know the MFG year of the motor that could be helpful too. Good luck
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 02-09-2007 at 12:07 AM. |
~Rest In Peace~
i like my pizza thick style
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
#5 | |
Sierra Grande Club
s/t
I checked summit, the 55-86 is called thick, the 1 piece frear seal is not called thin though, its just called 86-99
Yes yours is a 1st generation motor
'67 C20 Lwb 350 4-Speed '01 Chrysler Concorde LXI (wifes ride) '91 Gmc Suburban 3/4 2wd 454 Tbi '51 Jeep Cj3a "Willys" 350 V8 |
The way I under stand it there was a thin front and rear gasket from 55- 74 and 75 to 79 gasket the thick front and rear seals. Look up summits stock replacement oil pans in there catalog and it will tell you. 80 - 86 is a whole other animal, ie drivers side dip stick and 87 up is 1 piece rear main seal that also is a whole other animal oil pan gasket wise. Good luck.
GEARHEAD
It depends on the timing cover you are using. The older style was the thin (I'm not at the shop to mesure exact but) close too 1/4 inch thick is closer toa heavy 3/8's little less than 1/2 if memory serves me right. TTT for some one that cam mesure for sure.
