02-09-2007, 12:26 AM | #1 |
C10 to C20
Hello to all. I was trying to find out can you change a C10 to a C20. I have a 68 C10 2wd suburban and have trying to get a C10 truck 2wd or a K5 blazer on sure if 2wd or 4wd. If I get the truck I need it to pull the suburban and if the blazer need the suburban to pull the blazer.
Thanks for your time and help Lou |
02-09-2007, 02:05 AM | #2 |
Re: C10 to C20
the difference in a c10 and a c20 is the frame and suspension but theres no difference in bodies
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
02-09-2007, 02:15 AM | #3 |
Re: C10 to C20
Yes,you can change a C/10 to a C/20:Springs,rear axle,and steering knuckles-out(bearings/brakes)
02-09-2007, 11:30 AM | #4 |
Re: C10 to C20
If it is coils all the way around here is how you do it. This is the stock bolt in way.
1. Coil spring rear axle your choice of dana60 or ho52. 2. 3/4 ton panhard bar for the axle 3. 3/4 ton springs. 4. up front 3/4 ton springs 5. 71-87 3/4 ton lower a arm 6. 3/4 ton upper and lower ball joints 7. 3/4 ton 71-72 inner and outter tie rod ends 8. 71-87 3/4 ton spindales rotors and such. 9. 71-72 3/4 ton master cylinder and power brake booster with brackets. 10. 71-72 front 3/4 ton brake lines. I think I listed everything. Mount the upper ball joints in the stock 1/2 ton upper a arms, as the 3/4 ton a arms wont work do to the size of there pivot shaft but the 3/4 ton ball joints mount fine in the stock 1/2 ton a arm. Hope this helps. |
02-09-2007, 12:32 PM | #5 |
Re: C10 to C20
Will a C-10 front crossmember bolt into a C-20 frame?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-09-2007, 04:05 PM | #6 |
Designated A-hole!
Re: C10 to C20
Yeah
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
02-09-2007, 04:25 PM | #7 |
its all about the +6 inches
Re: C10 to C20
the frames are 99% the same.
02-09-2007, 06:06 PM | #8 |
Re: C10 to C20
Thanks for the info
02-09-2007, 06:23 PM | #9 | |
Re: C10 to C20
02-10-2007, 12:52 PM | #10 |
Re: C10 to C20
You will need items 6- 71-72 ball joints, 8- 71-87 spindles, half of 9- you will need a 71-72 master cylinder, 10- 71-72 brake lines and hoses. Yes the spindles will work with your a arms. But you will need a 71-72 center link to use the 71-72 tie rods, your tie rods wont work with the disc spindles. They make an adapter for the 1/2 ton tie rods to use a combo of the 67-70 and 71-72 tie rod ends that might work for you but am not sure. There was a few people that talked about this adapter but dont rember who it was or who makes it. Me I would just find the 71-72 center link off of either 1/2 or 3/4 ton truck. Hope this helps.
Aaron |
