02-09-2007, 08:39 AM | #1 |
WTB 81 -87 High Hump Floor Section
I have the 81-87 high hump trans cover but I need the mating section of floorboard to convert my 2wd cab. Willing to buy a complete junk cab for the section I need. Thanks.
02-20-2007, 11:45 AM | #2 |
Re: WTB 81 -87 High Hump Floor Section
to the top
02-20-2007, 11:32 PM | #3 |
Professional Grade
I've got what you need, but I have no idea how to get it to you... Its pretty big...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
02-21-2007, 08:21 AM | #4 |
Russell,
ALL I need is the section under the front seat. I can get the rest of the cover to fit with the existing floor. There was a few threads on this in the recent past on this subject that had pictures showing the area I need. I will see if I can find them and post the link. |
02-21-2007, 12:25 PM | #5 |
Professional Grade
I know which part you need -- Did the same thing myself, lol
I suppose I could cut the t-case hump off, but the part I have is one full solid peice from a cab that had a non-removeable hump in it. I'll snag a pic, but I do warn you, shipping on it won't be cheap...
03-16-2007, 06:08 PM | #6 |
Luv the Crewcabs
Did u ever get what u need, I have a 85 cab ...................
Thanks, Rick |
03-16-2007, 07:01 PM | #7 |
A few close calls but no high hump yet. What shape is the cab? I was hoping to find either just the sheet metal or a junk cab to cut the metal from.
03-16-2007, 10:36 PM | #8 |
Luv the Crewcabs
My Cab is Junk, Post a Pic of what u Need...................
Rick |
03-17-2007, 07:57 AM | #9 |
Here is a picture I grabbed from another post. I need the section in yellow. I could also use the tunnel cover itself if it is better shape than mine. Thanks.
03-17-2007, 07:49 PM | #10 |
junk collector
I have a 89 k5 that I currently rob parts from, but it is not a bolt in piece, it would have to be cut from the floor and my 87 k5 is the same. The bolt in sections were only a few years- early 80s I think. You are wanting a truck floor, so blazer and sub pieces wont do.
IIRC, the bolt in panels were thru 84.
'87/89/76 K5 in progress '99 K2500 short crew '91 camaro rs '98 jeep tj '52 willys cj3a |
03-17-2007, 11:07 PM | #11 |
I have an 86 parts truck without the bolt in hump but it is a high hump floor, If nobody comes through for ya let me know and I'll snap a pic of it.
03-19-2007, 08:01 PM | #12 |
03-30-2007, 09:35 AM | #13 |
Luv the Crewcabs
Here is some Pic's of what i Have, Is this what u are needing?
Thanks, Rick |
03-30-2007, 03:58 PM | #14 |
Here is what I need.
04-14-2007, 11:13 AM | #15 |
Luv the Crewcabs
Dave
Got this section cut out Yesterday, It's not That Great so if you still want it I will let u have it for Shipping Cost. Looked for a Box this morning w-out much luck, Will just Cardboard it........... Here are a couple of Pic's, Will need some clean up. Caught the Dash on Fire & Kinda made a mess before i got it Put out, Stared cutting with my Sawsall & broke the Blade & Torch was running out of Oxy. Should of known better than to mess with it on Friday The 13TH Rick PS Please keep your eye out for a 73-87 Stepside Bed for me, Need the Bed & rear Frame section for a Future Project. Open to a Full truck if Fairly Cheap ( 500.00 to 600.00 range ) Thanks, Rick Last edited by toomanytoyz; 04-14-2007 at 11:17 AM. Reason: Added Ps |
04-14-2007, 07:50 PM | #16 |
Are you in southern Indiana? If so how far from I-65? I am headed to KY tomorrow afternoon and back to Indy sometime around Thursday or Friday. I might be able to stop by and pick it up.
04-14-2007, 08:19 PM | #17 |
Luv the Crewcabs
Im north, Up by Ft. Wayne .................
If it looks ok for you I will get it Packaged up for you & go ahead & send it Rick |
04-15-2007, 01:29 PM | #18 |
Ok. I sent you a PM with my address. I am leaving this afternoon and won't be back till Friday. I can send payment for the shipping when I get back.
04-17-2007, 09:40 PM | #19 |
Luv the Crewcabs
Dave
Got the Panel Packaged up & went to Post Office & they said Package was Too Big, Then Went to UPS & THey Wanted $ 91.00 Cause it was oversize , Needless to Say it's Not getting Shipped................ Im going to Perrysville on Friday weather permitting to Pick up some Part's from Troy, Troy said it would be cool for me to leave it with him for you to Pick up. Will this work for you? Thanks, Rick Here is a Pic of the $91.00 Package |
04-21-2007, 08:45 PM | #20 |
Luv the Crewcabs
Dave ,
The Part is at Troys, Just give him a Call & set up a Time to pick it up. Rick |
