Old 02-09-2007, 09:55 AM   #1
ocbaud
Garage Queen Material
improving fuel milege???
anyways to help with fuel economy in my truck???
any little bit help, it averages about 11mpg right now.
here are the specs on it
355ci
10:1 Compression Ratio
Holley systemaxII alum. heads
Comp cams 270H magnum
Holley street dominator intake
MSD Pro-Billet distributor #8361
MSD Blaster2 Coil
MSD 6AL Ignition box
Edelbrock Thunder Series 650cfm AVS carb
Aeromotive Billet Fuel Pressure Regulator
shortie headers
K&N 4" Open Element air filter
3.73 gears
Eaton Limited-Slip Diff.
Th350c transmission
2800 stall torque conveter
B&M Stacked plate trans cooler
trans-go transpack
i'm thinking a new carb, but the one i want is SO expensive (650cfm mighty demon)
and i plan on getting a built up 700r4, but those are expensive too and the torque converters are expensive for them too!
ocbaud is offline   Reply With Quote
