I bought a Holley carb from ebay, and it was supposed to be a model #4175. It is a spread bore with vacuum secondaries, but it does not have a electric choke, which every other one of them I have seen (including old ones )has.
I will try to post a pic of the one I bought, and the one on the Holley web site. My question is, is the one I bought a manual choke, or is there something missing. The one that I bought: The pic from the holley website: ![]()
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
try to domore of a closeup on the side that is supposed to have the choke on it so we can better compare the two if u can
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
I really don't have a way to take a pic of it right now, the one I posted is just the one from ebay, if you can tell me what to look for I can do that too. Here is a pic of a 4160 that shows the choke from a different angle
![]() ![]() This is a pic of a 4160 with a manual choke, but this doesn't look like what I have either. I looked at it again, and I don't think it even has a place to attach the electric choke, but I am not sure.
Glowing since 1978
I would say that the choke for your carb was probably a divorced choke in it's previous setup. It consist of a plate with a bimetallic coil that is attached to the intake manifold above the heat crossover and the end of the coil is attached to an operating rod which automatically takes the choke off when the engine heats up. This is my favorite type of choke setup. As long as you don't mind having the heat crossover unblocked.
------------------ 66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 79 Chevy 4X4 (Tom's old truck)
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
CCRider
I would say that ddsmith hit it right. That is a q-jet replacement carb, and most older applacations are divorced choke.
------------------ 72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
I agree,its probably a divorced choke set up. It is a 4175(spread bore/vac 2nds/no metering block on secondaries). If you post the stamped numbers on the air horn,I have a couple books.....may be able to give you the specs on it........69
http://community.webshots.com/user/hotrodhorn |
Are any of these what you need? That is all of the stamped numbers Icould find. If it is a divorced choke, could I just get a Holley electric choke conversion kit?
list-7855 2549 L7855 7445 8174
TTT
I have another question about the same carb. I have A/C and a automatic transmission and I can't tell if the carb will clear the vacuum fitting in the manifold. I will probably either use a Edelbrock Performer, or a Weiand Action Plus manifold, and I need to know if I will have to ues a spacer?
should be alright on both or those..i have a holley on a weiand intake and it works fine.......
------------------ 1972 swb, 400 sbc, 1978 malibu classic,305 balanced and bluprinted flowmasters,2 1/2 exhaust,pulleys,k/n 4" power filter,750 edelbrock carb,plus lots more......
1972 swb, 400 sbc, 1978 malibu classic,305 balanced and bluprinted flowmasters,2 1/2 exhaust,pulleys,k/n 4" power filter,750 edelbrock carb,plus lots more...... RIENZI,MS ...just southeast of Memphis... |
hey larry, there should be a 4 digit number right inside the air horn where the air goes inside the carb..it will be on the driverside of the carb facing up toward the hood...that number should be able to get you the info you need i think...jv
I couldnt find much info on the choke setup,if it is a divorced set up,the elc choke wont bolt on. My book says....0-7855,direct replacement for all carter thermo quad carbs on 75-76 440(A-134)performance option engines. Vacumn secondaries,single pump,spreadbore 650 cfm,emissions carb. You might give Holley site a look,or call for info on the choke. http://www.holley.com/
