autometer cluster question
I am doing the behind the bezel autometer conversion. I have a question for those who have done it. The 2 5/8 gauges what ones are harder to see and what ones are better to see while driving? I Want to arrange them in order of importance ya know.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Post Whore
![]() Join Date: Feb 2000
Re: autometer cluster question
It may be because my swapped in seats sit me kind of high, but I can see all of my smaller gauges pretty well. The ones on each side of the column are probably a touch more difficult to keep an eye on. I put my fuel gauge on the far right side and I like it there as it is easy to keep an eye on and fun to watch how fast I run low on gas. To the far left I have the temp gauge - always keeping on eye on the temp so I like it over there. Just to the right of my column is the clock - don't really care much about time cause when I'm in the truck time just doesn't seem to matter much. Voltmeter is just to the left of the column - kinda keep an eye on it but if I should have a electrical problem, I will know of it by the wires a frying.
Guess those are the reasons for how I have my small gauges set up the way I do.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#3 | |
![]() Maybe that's mounted elsewhere...
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
Post Whore
My oil pressure gauge is the larger 3 3/8" gauge between the speedo and tach - I thought he was just asking about the smaller 2 5/8 gauges.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 02-10-2007 at 08:38 AM. |
![]() Join Date: Feb 2001
Autometer makes small rings that you can put behind the guages when you mount from the front to angle them any way you want.
