02-09-2007, 10:41 PM | #1 |
70+ ( Old Skool Club )
Does Anyone Know !!
I've decided to keep my stock gauge setup (seeing I have the tach ) and I want to put the stock/factory vacumn gauge in my truck so I wont have an empty hole in my stock gauge cluster.. I know I can buy the replacement gauge from a couple of different places but can someone guide me to a site or tell me what parts I need and how to install the gauge so it will actually work !!
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-09-2007, 11:14 PM | #2 |
Re: Does Anyone Know !!
It should just need a rubber or plastic vacuum line connected to full manifold vacuum on your intake. As far as mounting it in the cluster, the inner and outer tins are different and so is the clear plastic lens.
I've had good results buying from GMC Pauls. He has good prices and good products.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-10-2007, 01:24 AM | #3 |
Thanks for the reply. Any suggestions as to where a good place to get vacumn from on my intake. I have a 396 with the stock intake..
02-10-2007, 01:40 AM | #4 |
If you can tap into the line going to your brake booster, that would be easy.
02-10-2007, 03:58 AM | #5 |
Thank You Clay and I checked GMC Pauls Site and he has a complete kit to put in the vacumn gauge and reasonably priced at 165.00.. Now to figure out which , engine oil temp, clock and trans temp gauges to put in the Just Dashes Tri Pod Dash Pad.. I would love the Autometer Carbon Fiber Series but they dont offer a clock in that series. Classic Instruments GStock gauges look very close to our stock gauges but they too dont offer a trans temp gauge that series..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 02-10-2007 at 06:58 AM. Reason: typos |
02-10-2007, 10:06 AM | #6 |
[QUOTE= I would love the Autometer Carbon Fiber Series but they dont offer a clock in that series. Classic Instruments GStock gauges look very close to our stock gauges but they too dont offer a trans temp gauge that series..[/QUOTE]
did you call Autometer? if not i would ---they sometimes do special orders
69 chevy swb 2.5 in droped spindle with 1 coil cut--5 in dropped spring in rear 5 in dropped spring 307 repaced soon with 350 3sp on tree soon replaced with 350 tubo 06 monte carlo 94 chrysler town & country---198K 84 jag xj6 76 sportster---57 panhead |
02-10-2007, 05:01 PM | #7 | |
Thanks ,I'll try that.. I was also going to call Classic Instruments to see if they would special order a trans temp gauge for the GStock line. , but my preference would be the Autometer Carbon Fiber gauge.
