02-09-2007, 11:33 PM | #1 |
Where does headlight grounding wire go?
I am putting my truck back together and on the driver side my headlight grounding wire has two places to ground it? Looks like one goes to the core support and the other looks like it could go to the regulator? Any ideas? Thanks
02-09-2007, 11:45 PM | #2 |
Re: Where does headlight grounding wire go?
you probably know better than i, and many on the board will be more accurate...
as my 71 C10 has the grounds both attached to the front radiator wall, (core support), to the bolts holding the regulator. but then, this one was sincerely spliced by the PO. |
02-10-2007, 09:37 AM | #3 |
Thats what I thought, just can't figure out why? Thanks
02-10-2007, 11:11 AM | #4 |
River life......
I used a 1.5" bolt through and existing hole in the support, put one nut on it and tightened it down, then the wires then another nut to hold them tight.
02-10-2007, 11:17 AM | #5 |
I also combined mine to one ground point. As long as you have good continuity you should be ok. The only exception might be if the regulator needs a separate ground because it's mounted by rubber isolators, that's the only reason I can think of for GM to put a separate ground wire there. Most times those rubber mounts are long gone and the reg is mounted to metal.
Looks like a nice excuse to do the internal regulator conversion...
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-11-2007, 09:38 AM | #6 |
I have new rubber mounts to the regulator, I wasn't sure if those were for vibration reduction or to keep it from grounding. I guess I will run the other ground to the regulator since it looks like that is where it belongs. Thanks
02-11-2007, 10:13 AM | #7 |
71 rustless in texas
there is a ground to the regulator "body", but it isn't part of the wiring harness. It's a seperate piece of wire about 6" long. the headlight ground to the core support (front sheetmetal) and so does the regulator. It shouldn't matter if they are both grounding at the same spot.
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE |
